Last updated by Ferry Vanacker 10 months, 4 weeks ago.
Assigned support staff: Radu.
August 16, 2019 at 6:52 am
Ferry Vanacker
I am trying to: go to String translation and trying to open only Gravity Forms ID 4, but the page is not refreshing (hidden link)
I expected to see:only the Gravity Forms ID4 fields, but the page is not refreshing
Instead, I got: Nothing, i click on Gravity Forms 4 and nothing happens. Also, when i try to look for a translation and click Search, nothing works
August 16, 2019 at 11:58 am #4406171
Radu
Hey Ferry,
Can you try to access this link, please? hidden link
This is the page that opens once you select the gravity_forms-4 from the dropdown. I tried to select it right now and everything works fine on my side. Can you give it another try, please? Maybe this was just a temporary issue.
Radu
August 19, 2019 at 10:45 am #4415319
Ferry Vanacker
I can't click a thing when i go to that url. Can't click on Translate because nothing is happening. Not in Chrome, also not in Firefox, Edge and Internet Explorer. Also tried on Macbook Pro, Macbook Air and windows 10 console.
Nothing works. Maybe some look-a-round with Teamviewer so you can see what happends on my side?
August 21, 2019 at 8:17 am #4429015
Radu
Hey Ferry,
I'm sorry but we can only talk through these tickets. Is there any chance that you could tell me what version of MacOS and Safari are you using, please? For example, I'm using MacOS 10.14.6 and Safari 12.1.2 (14607.3.9) and I can press any button.
Is there any chance that you could create a short video so I can see how things work on your side? You can use a free online tool like hidden link to do a video.
Radu
August 21, 2019 at 8:54 am #4429203
Ferry Vanacker
Made my own solution. For the costs of WPML, the support is very very bad
