This topic contains 20 replies, has 2 voices.
Last updated by julianZ-4 1 year, 9 months ago.
April 2, 2020 at 4:28 pm #5824767
julianZ-4
Hi Andreas
Thanks a lot.
The website is migrating now and should be finished soon.
Julian
April 2, 2020 at 4:42 pm #5824883
julianZ-4
Hi Andreas
Migration is complete 🙂
Julian
April 2, 2020 at 5:19 pm #5825399
Hi Julian,
The Logo issue is triggered by LocoTranslate.
I would suggest you avoid using this plugin as it is not recommended to use two multilingual plugins at the same time.
What was the reason for you to install LocoTranslate apart from WPML? Did you use it to solve translation issues with WPML?
Kind regards
April 2, 2020 at 5:40 pm #5825541
julianZ-4
Hi Andreas
Thank you very much for investigating!
It seems to be LocoTranslate, indeed. I just checked it on live system.
I actually don't know. I most probably had loco translate installed before WPML to translate some theme functions because it's easy to use.
I will check tomorrow if I can translate everything with WPML string translation and will get back to you.
Again, thank you very much for helping!
Julian
April 2, 2020 at 6:26 pm #5825973
Hello Julian,
I am glad to know that we sorted this issue.
Do not hesitate to reach out if you need further assistance.
Kind regards
April 2, 2020 at 6:45 pm #5826051
julianZ-4
