I would like to export English string translations using the Import/Export feature in WPML -> String Translation.
However, English is not display as a target translation language.
Please use this workaround.
Go to: /wp-content/plugins/wpml-string-translation/menu/string-translation.php
and remove this code:
if($al['code']==$string_settings['strings_language']) continue;
This will enable export in any language.
0% of people find this useful.
Last updated by fabiantodt 3 years, 1 month ago.
Assigned support staff: Dat Hoang.
January 13, 2017 at 10:07 pm #1182064
Miguel
Hello!
Because I'm getting to much problems with string translation, I am trying to export all the strings to a .po file. My default language is Spanish (basque, english and french installed too).
I expected to see "basque, english and french" in the select form.
Instead, I got "basque, spanish and french"
Thanks a lot! 🙂
January 16, 2017 at 9:17 am #1182694
Dat Hoang
I think this is a missing feature of our plugin.
I'm reporting this to our 2nd tier supporters and our developers.
Will get back to you soon.
January 16, 2017 at 9:26 am #1182700
Dat Hoang
I reported it already.
Will let you know if we have any info.
January 18, 2017 at 9:47 am #1184692
Dat Hoang
Please go go to: /wp-content/plugins/wpml-string-translation/menu/string-translation.php
Please try it and let's see that does help or not.
January 18, 2017 at 10:20 pm #1185425
Miguel
Hello!
It works perfect! Thanks a lot! 🙂
October 17, 2018 at 1:05 pm #2824664
fabiantodt
this is still the case - for me this seems like a bug or i don't understand how to use it 😀
my use case: we've got a german site (default language) with english translations. i translated most of the strings on my local development environment. now i want to export the english translations (because german is the default language of the strings and already there) and import them on the production site. but i can't select "english" in the dropdown except i apply the workaround of yours. but even if i do that, i can't import the english strings on the production site - only the german ones are imported.
maybe i'm doing it wrong - what's the correct way to do that?
