Last updated by Sumit 4 years, 2 months ago.
Assigned support staff: Sumit.
May 17, 2017 at 10:20 am #1278018
attiahA
Hello
i face a many problems with WPML
the user menu in English take the Arabic translation
and some translation in Arabic when the page load shown fine and after the page completely load the strings changed to the other language English something crazy
i record this video
i try to deactivate all plugins one by one and the problem not solved .
i confirm the problems comes from the WPML or any setting modified by WPML Support in my website
May 17, 2017 at 1:32 pm #1278254
attiahA
i can get any replay ???????????????
May 17, 2017 at 3:32 pm #1278367
Sumit
Thank you for opening a new thread!
#1 Can you please go to WPML > Languages > Language filtering for AJAX operations : and make sure you have checked "Store a language cookie to support language filtering for AJAX"?
#2 I can not see a submenu of payment parent menu. Can you please explain me how can I see this menu?
May 17, 2017 at 5:29 pm #1278474
attiahA
Hello
WPML > Languages > Language filtering for AJAX operations not checked and after i check it no any changes in our problem
the sub menu sure for users you can register a user or open the private replay and i will give you the access information to see all the problems with your self directly and to decrease the time for replays from me and you
May 18, 2017 at 6:46 am #1278783
Sumit
I need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Instructions to send private information are here: hidden link
Privacy and Security when Providing Debug Information for Support:
May 18, 2017 at 1:51 pm #1279294
Sumit
#1 Menu issue: I am still not seeing the menu you have shown in the video! When I hover on payment button nothing happens. Please let me know the steps to see this menu!
I am attaching the screenshot for the same.
#2 About "CONTINUE COURSE" string: You haven't translated this string yet. Please go to String Translation and find the string "CONTINUE %s COURSE" then translate this. Please don't remove %s from translation.
#3 About course strings issue: - I am seeing a javascript error from BuddyPress. The localization script is 404. In source code, I am seeing the wrong URL of js file
<script type='text/javascript' src='<em><u>hidden link</u></em>' defer '>
The file path is not correct. And this transaltion is not coming from WPML. It is from MO files.
Are you using some kind of defer javascript parsing method? It is causing an issue with the above js file.
May 18, 2017 at 2:11 pm #1279322
attiahA
#1 Menu issue: for the menu hover over or click in username i mark it in the attached image
#2 About "CONTINUE COURSE" i translate the string as you say and the problem solved
#3 About course strings issue: i use an code to defer javascript in my functions.php
add_filter( 'clean_url', 'defer_parsing_of_js', 11, 1 );
function defer_parsing_of_js ( $url ) {
if ( FALSE === strpos( $url, '.js' ) ) return $url;
if ( strpos( $url, 'jquery.js' ) ) return $url;
return "$url' defer ";
when i remove it this problem solved but i want to defer javascript how we can do this in safe method
May 19, 2017 at 8:39 am #1279883
Sumit
Okay! Now I can see the issue! Looks like the strings you have translated in String Translation are not correct and it is coming from plugin settings.
I need to debug this issue locally I am unable to check it on your site!
For this, I'll need to temporarily install a plugin called "Duplicator" on your site. This will allow me to create a copy of your site and your content.
Once the problem is resolved I will delete the local site.
Please let me know if it is okay?
About defer javascript issue: This code is not correct! You can not add defer attribute in URL it needs to be added as a tag.
Currently, scripts tag looks like
<script type='text/javascript' src='<em><u>hidden link</u></em>' defer '></script>
But it should be like
<script type='text/javascript' src='<em><u>hidden link</u></em>' defer='defer'></script>
There are many free plugins! You can install and tests.
OR you can also contact one of our certified partners from this link: http://wpml.org/documentation/support/wpml-contractors/
You will get the custom assistance you need to get on with your project.
Before doing so please have a look also here: http://wpml.org/documentation/support/wpml-contractors/guidelines-for-people-looking-for-consulting-help/
May 19, 2017 at 9:50 am #1279944
attiahA
Ok you can do it
Duplicator installed in my website
Just small hint
My website url and all url redirect to
May 19, 2017 at 3:08 pm #1280360
Sumit
I am sorry it took me a little long time because I was thinking that it is core theme issue as you said you have checked by disabling each plugin.
But the issue is coming from "Vibe Custom Types" plugin.
This is not a WPML issue instead results of using wrong WPML API.
The theme is translating these links using WordPress localization functions in this file \themes\wplms\templates\login\full_login.php line number 20
There is a filter called "wplms_logged_in_top_menu".
"Vibe Custom Types" using this filter and translating again those values that are already translated.
\plugins\vibe-customtypes\includes\loggedin_menu.php line number 27
Please let the theme support know about it.
Meanwhile, as a workaround, you can go to \wp-content\themes\wplms\templates\login\full_login.php line number 60 and comment out this line.
How to comment out:-
Replace this code
$loggedin_menu = apply_filters('wplms_logged_in_top_menu',$loggedin_menu);
with
//$loggedin_menu = apply_filters('wplms_logged_in_top_menu',$loggedin_menu);
NOTE: Please make a complete backup of site files and database before you proceed (Just a good practice!)
May 19, 2017 at 5:54 pm #1280528
attiahA
Thanks i have open a support topic in the theme support forums and waiting theme support replay
May 22, 2017 at 9:28 am #1281351
Sumit
I am sorry I can not see the replies on their forum! It is visible only for logged-in users.
Meanwhile, did you try the workaround? Does it work for you?
