Last updated by Andreas W. 1 year ago.
May 3, 2019 at 4:05 pm #3736533
giuseppes-10
when i active string translation component or WooCommerce Multilingual, the site stop working
I have:
WordPress 4.9.10 with theme Oshin
woocommerce 3.4.5
help me , thank's
by
Sergio
May 3, 2019 at 8:35 pm #3737855
Thank you for contacting WPML Customer Support.
Please download the latest versions of WPML Multilingual CMS 4.2.6 at https://wpml.org/downloads.
Deactivate and delete all WPML plugins. Do not worry, this process will not affect your translations and settings stored in the database.
Add WPML Mulitlingual CMS 4.2.6 again.
Then go to Plugins -> Install -> Commercial and download the add-ons. Also, select the "Enable After Download" button at the bottom of the plug-in selector.
Also make sure to update WooCommerce and andy other used plugin, as your theme as well.
Did you further consider to update WordPress to 5.1.1?
Please let me know if the issue has been resolved.
Yours sincerely
May 6, 2019 at 9:58 pm #3752829
giuseppes-10
I updated plugins and wordpress, removed and re-installed wpml but when I activate WPML String Translation, the site crashes ... white screen on both front and backend
May 6, 2019 at 10:06 pm #3752837
Could you please try to run the site in minimal setup to see if the issue persists?
Please disable any additional plugin that is not related to WPML and its add-ons. If the issue disappears please start reactivating any plugins, or activate them in small groups. This way please verify at which points the issue appears again to indicate the plugin that is causing the issue.
Also please change to a default theme like TwentySeventeen to see if the issue might be theme related.
Further, you could enable the wp-debug feature to see if there are any current PHP errors given.
More information about how to activate this feature you can find here:
Kind regards
The topic ‘[Closed] String Translation problem’ is closed to new replies.
