Last updated by Raja Mohammed 1 year, 1 month ago.
June 25, 2019 at 9:14 am #4082575
andrewW-27
Hi, I have translated the string "Change shipping country" in backend, but it do not appear in website front end.
Shall I know how I can fix this ?
Looking forwards to your reply.
Andrew
June 25, 2019 at 10:43 am #4083397
Raja Mohammed
Hi Andrew,
I will help you with your issue,
Please go to WPML > String translation and search for the string "Change shipping country" check if there is more than one string appear for translation share a screenshot of the string translation table.
Please let me know whether the string in question is added by any plugin if yes, Please let me know if there is any provision to alter or update the texts, In such cases, the Strings will be available as admin texts we have to add the appropriate admin text string for the translation to work
https://wpml.org/documentation/getting-started-guide/string-translation/#admin_texts
If you are stuck please share temporary access to your site, Let me check the details for you
Kind regards
Raja
June 25, 2019 at 12:48 pm #4084703
Raja Mohammed
Thanks for the information,
I have checked a few parameters in your site. However, it doesn't help much.
Please update the WPML plugins to the latest version check if that helps, If that's not helping much, I would request a snapshot (copy) of your site, You can use the Duplicator plugin to create a snapshot of the site and share the package link with me http://wordpress.org/plugins/duplicator/. I have enabled private fields for you to securely share the details.
Kind regards
Raja
June 26, 2019 at 9:26 am #4090879
Raja Mohammed
I have tested the issue it seems to be happening with minimal setup. To isolate the issue I have created a test site ( clean WordPress site ) Which can be accessed from
One Click Login: hidden link
Please try to replicate the issue, Add a few dummy Flat rate shipping zones check if you can translate the string "Change shipping country" in the sandbox site. Please let me know the results
Kind regards
Raja
June 26, 2019 at 11:00 am #4091753
andrewW-27
Hi, I have tested your site and I found the problem is solved. Shall I know how I can fix this in my site ?
Andrew
June 26, 2019 at 12:27 pm #4092469
Raja Mohammed
Please try adding shipping methods and make it visible in the front end, Maybe that's the key we are missing here. Let me know if that helps.
Kind regards
Raja
June 26, 2019 at 2:25 pm #4093225
andrewW-27
Hi, I have added the shipping methods, and tested. The demo site do not have problem we faced. The string can translate prefectly. Attached please find the screencap....You can see the translated string "變更地址".
Any thing you have done to make this work ? Please advice.
Andrew
June 27, 2019 at 3:30 am #4096331
Raja Mohammed
I have checked the issue in detail, For some reason, the cart-shipping.php template in your WooCommerce plugin has been altered and the text "Change shipping country" has been hardcoded to the function woocommerce_shipping_calculator ( check the attached screenshot).
To resolve the issue please upload a fresh copy of WooCommerce plugin to your site, do not make any customization to the WooCoomerce core plugin files.
I hope this helps you resolve your issue.
Kind regards
Raja
