Last updated by Dennis 1 year, 1 month ago.
Assigned support staff: Dennis.
April 29, 2019 at 7:28 am #3700543
MOOI
Sorry Dennis I found one more sting which won't translate: the "rock_slider_content" Home page "A GURULÓ SZÓRAKOZÓHELY!" could you give me hint for the sting code?
Thanks a lot!
April 29, 2019 at 7:34 am #3700589
Dennis
I have already deleted the copy of your website on my computer.
Can I request again for a temporary access for your site (/wp-admin | FTP) so I can check and continue debugging?
Also, I can't seem to find the string on your homepage. Could please show me were I can find it from the frontend? It would be of great help if you can share some screenshots.
Kind regards,
Dennis
April 29, 2019 at 12:17 pm #3703089
Dennis
Could you please try these steps?
-go to WPML > Theme and plugins localization
-tick 'Use theme or plugin text domains when gettext calls do not use a string literal'
-click 'Save' button
-select your theme (rockon)
-click 'Scan selected themes for strings'
-go to WPML > String Translation and search that string. It should be under 'default' text domain'
-translate the string completely and save.
Does it help? Please let me know.
Kind regards,
Dennis
April 29, 2019 at 12:38 pm #3703201
MOOI
Hmm, seems to be the same like for other two, although I translated the sting it won't appeare for hungarian language. 🙁
April 29, 2019 at 2:01 pm #3704131
Dennis
Thank you for your reply.
Could you please increase the WP Memory Limit (your current setting is 40M). Minimum requirements are 128Mb:
/** Memory Limit */
- Add it above the line
Also, I would like to recommend you to increase your max input vars, currently it has a value of 1000 in your WordPress Dashboard > WPML > Support section.
Please, try to increase it to 5000. You might need some assistance from your host to properly set this up.
See:
Kind regards,
Dennis
