Using strings directly in php file, how to translate these strings?
To translate these strings, you must use some gettext function, such as "_e()" or "__()". For example:
<?php _e( "Created and managed by" ); ?>
Relevant Documentation:
https://codex.wordpress.org/L10n
https://codex.wordpress.org/Function_Reference/_e
Last updated by gentianG 4 years, 6 months ago.
March 29, 2017 at 8:36 am #1242061
gentianG
Dear Support,
I have been trying to translate several strings on dardan.al.
Attached you will find a screenshot (dardan-screenshot-string-translation.png) in order to create a better idea.
As you can notice from the screenshot strings are mixed up with both languages. Albanian and English. And this is not the only concern.
As we try to translate those strings into corresponding language, we have noticed that in English no changes are made, strings are not updated, it is same content as it is in Albanian version.
What would you suggest us as solution?
Kind Regards,
March 29, 2017 at 6:24 pm #1242691
Bruno
Thank you for contacting us.
I noticed that on the form you are using Contact Form 7.
To translate Contact Form 7, you must follow the steps in our documentation: https://wpml.org/documentation/plugins-compatibility/using-contact-form-7-with-wpml/
Also, as you are adding this form within the Widget, you can use WPML Widgets to add shortcodes in other languages. You can see our documentation here: https://wpml.org/2014/08/display-different-widgets-per-language-wpml-widgets/
On the other strings, are these strings being displayed inside the WPML > String Translation? If yes, are the strings selected as "Translation is complete"? I'll attach an image as an example.
April 4, 2017 at 9:12 am #1246593
gentianG
Hello again,
Thank you for your support. We have followed your instructions and
1. Contact Form---> Done
2. Widgets --->Done
3. Footer copyright---Still Need Assistance
We have tried to translate strings of footer.php, did a theme scan serveral times and we still are not able to find those strings(from scan "Created and managed by" strings are not generated). For a specific reason, strings are not found.
What would you suggest?
Thank you in advance,
April 4, 2017 at 2:01 pm #1246936
Bruno
This may be how the footer is being created. Where do you edit the footer content? Is this just in the footer.php file? Or do you edit this content within an option of your theme?
For the string to be translatable, the string must be using gettext functions. For example:
Is the string in this format? If not, please could you try to verify that the string is displayed in String Translation?
If the problem persists, I need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help.
*** Note: Please make a full backup of your site.
Privacy and Security when Providing Debug Information for Support: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
May 22, 2017 at 9:27 am #1281350
gentianG
