Problem: The language switcher is not displaying on the website.
Solution: The reason the language switcher was not showing up was because you had not translated your content. As you can see, I duplicated the homepage into the secondary languages and now the switcher appears in your menu. It will only display on pages that have translated content.
To translate the homepage that I duplicated, open each translation and click "Translate Independently". Then you can add your translations and click Update.
Last updated by harrieM 2 years, 8 months ago.
October 25, 2016 at 10:34 am #1122453
harrieM
See my website on hoteldonandres.com. Login with user 'xxxx' and password 'xxxx'. [edited by WPML support]
Where do I have to insert <?php do_action('wpml_add_language_selector'); ?> in theme Bridge (Qode)?
October 25, 2016 at 3:24 pm #1122814
Lauren
This will depend on where within your site you want the language switcher to display. If you want it built into the end of your menu, you can select that in the WPML -> Languages -> Language Switcher Options. If you want it to appear in a widgetzied area, you can go to Appearance -> Widgets and drag the Language Switcher widget to your widget box. If you want it to display in a custom spot in your site, then you would want to edit the theme template file and drop in this code where you want it displayed:
For example, if you want the language switcher to display somewhere in your header, then you would want to edit header.php (which you an do by going to Appearance -> Editor) and then adding that code where you would like it displayed. If you add it to a theme file, I suggest creating a child theme and copying the file to your child theme so that the changes do not get overwritten when you update your theme.
October 25, 2016 at 3:51 pm #1122848
harrieM
Can you please have a serious look..? It;s NOT WORKING! Please don't give me a standard answer. As you could see in the printscreens, i did ajust it the way you told me. So please login on the website and have a look.
October 25, 2016 at 4:50 pm #1122897
Lauren
I will be happy to take a look. I will need the server authorization password to access your site, and also I deleted your login information from the original post as that is open to the general public.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
October 25, 2016 at 5:52 pm #1122943
harrieM
I'm not sure about the password for wordpress: so here is a new one: [removed by WPML support]
October 25, 2016 at 6:20 pm #1122963
Lauren
I need a username and password for the server authentication page (I have attached a screenshot). I can't even get to the admin page to login.
Also, please refrain from posting password or sensitive in formation in regular posts. Make sure that I have marked the field as private, this is for security reasons. I have edited the previous post, so please repost the updated WordPress admin password in the next reply, along with authentication credentials.
October 25, 2016 at 8:08 pm #1123012
Lauren
Neither of those is working. Please check with your hosting provider to see if my IP could be blocked or if they can allow me access. Next reply is private in case you need to update credentials.
October 26, 2016 at 7:55 pm #1123949
Lauren
I still can't access the login page, it is still asking for authentication per my screen shot above. My IP is 75.182.18.219.
October 27, 2016 at 3:03 am #1124056
harrieM
Hello Lauren,
there are no screenshots in your post..?? But before login in uou have to use 2x 'xxxxxx' [removed by WPML support] before you enter the WP-login screen. Is that te problem. It's an extra loginscreen for extra safety. So please 2x 'login'.
Gr.
Harrie
October 27, 2016 at 2:42 pm #1124545
Lauren
Thanks, that was the login that I needed. I was able to access the dashboard of your site and the reason the language switcher was not showing up was because you had not translated your content. As you can see, I duplicated the homepage into the secondary languages and now the switcher appears in your menu. It will only display on pages that have translated content.
October 27, 2016 at 2:52 pm #1124552
harrieM
Hi Lauren,
Excuse for the misunderstandment about the 'login'. In the dutch language there's a clear explanation about that login in the pop-up. I saw that that explanation isn't there in the English version.
But I'm very happy that it's working now! Tx for your help. Wish you a nice day (i think it's in the morning in your place?
Greetings from the Netherlands!
