Last updated by gernotR-2 1 year ago.
April 19, 2019 at 12:18 pm #3645669
gernotR-2
I am trying to: synchronise the availability of products and don´t make my website crash
Link to a page where the issue can be seen: whole shop system where I did not manually change the stock
I expected to see: same amount of products and same product variations in all languages
Instead, I got: error sites, no synchronisation at ALL between products -> i had to deactive wmpl multilingual
April 22, 2019 at 5:12 am #3653925
Shekhar Bhandari
Hello there,
You mentioned you can see errors on the sites, Is it possible for you to attach a few screenshots showing the issue.
Also, since you are trying to synchronize the products while the crash is happening, it must be due to some php errors happening on this site, so, could you please perform the below steps and share me the results?
Debugging
1. Please follow the debugging information provided here: http://wpml.org/documentation/support/debugging-wpml/
2. Repeat the action of creating the problem.
3. Copy and paste the contents of debug.log (log file inside the /wp-content/ directory) here for me to see.
Look forward to your reply.
April 23, 2019 at 4:29 pm #3666191
gernotR-2
Hi, thanks for your answer. I followed the instructions. Where do I post the debug.log for not everyone to see it?
April 24, 2019 at 4:22 am #3669227
Shekhar Bhandari
Hello there,
I have enabled the private reply so you can post the debug.log in the next reply.
April 25, 2019 at 4:22 am #3678751
Shekhar Bhandari
Hello there,
PHP Fatal error: Maximum execution time of 192 seconds exceeded in /home/htwyinjq/gentletent.com/wp-includes/class-wp-hook.php on line 106
I can see the following issues on the debug.log, we have a similar issue which is related so, could you please use the solution provided here and let me know if this helps?
https://wpml.org/errata/timeouts-with-woocommerce-multilingual-4-6-1/
May 3, 2019 at 2:33 pm #3735493
gernotR-2
Hello, the solution you mentioned says "Resolved in WooCommerce Multilingual 4.6.2" - well for me it is still not working. Do I have to follow the instructions or not? Or is there another solution?
May 6, 2019 at 9:40 am #3746579
Shekhar Bhandari
Hello there,
It's not needed, to debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
So could you please provide me those details, you will find the needed fields for this below the comment area when you log in to leave your next reply.
Note:
May 16, 2019 at 9:10 am #3823571
gernotR-2
