This topic contains 22 replies, has 2 voices.
Last updated by Bigul 7 months, 2 weeks ago.
June 19, 2020 at 11:10 am #6411575
violaH-2
Stock amount in German and English product is not identical.
German 2-0-5-5 for S-M-L-XL
English 5-5-5-5 for S-M-L-XL
it seems that the stock available is taken from the product variant with the lowest WordPress ID (5)
I did the following
- update product translation
- update product german
- update product english
- Woocommerce - Multilingual - troubleshooting:
Sync product stock quantity and status ( synchronizing min stock between translations ) 1569 left
the sync needs 5 seconds
Sync product stock quantity and status ( synchronizing min stock between translations ) 0 left
with reload of that page
June 19, 2020 at 2:16 pm #6412635
violaH-2
English Product Link
June 22, 2020 at 6:57 pm #6429203
Bigul
This may be happening because of the older version of WPML and WooCommerce. So please try the following steps after a full site backup and make sure the issue is existing or not.
1) Upgrade to the latest version of WooCommerce(4.2) - hidden link
2) Upgrade to the latest version of WPML(4.3.15 series)
3) Clear all types of caches
4) Open Product for edit in the default language
5) Make a minor change in the contents to refresh the translation settings. Update the Product
6) Update the translation
Bigul
June 29, 2020 at 6:49 am #6473043
violaH-2
I did the upgrade and discovered that stock is not calculated right for products with umlauts in the custom attribute
with ascii custom attribute
with umlauts in custom attribute
June 29, 2020 at 2:26 pm #6477675
Bigul
Thank you for the updates. We have a known issue while using special characters for Custom Attribute labels. So this may be related. Please check the following URL for more details.
https://wpml.org/forums/topic/can-not-translate-swedish-attribute-label-containing-aao-to-german/
Therefore please share with me the values you are using for the German custom attribute labels. It will help us to troubleshoot the issue on our test installations.
Bigul
June 29, 2020 at 4:01 pm #6478881
violaH-2
hello,
the custom attribute is named "Größe" and the values for that are below.
It is a custom attribute and used for product variations.
"S | M |  L |  XL"
"3-6 Monate / 60-66 cm | 6-12 Monate / 66-76 cm | 12-18 Monate / 76-86 cm | 18-24 Monate / 86-93 cm"
"1-2 Jahre / 86-92 cm | 3-4 Jahre / 98-104 cm | 5-6 Jahre / 110-116 cm | 7-8 Jahre / 122-128 cm | 9-11 Jahre / 134-140 cm | 12-14 Jahre / 146-152 cm"
June 30, 2020 at 9:18 am #6483673
Bigul
Thank you for the updates. But I am not able to reproduce the issue exactly in our test installations with the latest version of WPML(4.3.16 series). Therefore I have a request please visit the following Sandbox site and check you can reproduce the issue or not. It is a fresh installation WPML plugins and WooCommerce, and the theme is default 2020. Because as part of our escalation process we have to make sure the issue existing in minimal or fresh installations.
Sandbox Site Login URL:- hidden link
English Product:- hidden link
German Product:- hidden link
Are you translating the Products Manually? If so, please translate the products using WPML Translation Editor(from WooCommerce>>WooCommerce Multilingual>>Products) and check is there any difference in the result or not.
Bigul
July 1, 2020 at 10:25 am #6493929
violaH-2
thank you for the system.
For translation I use Woocommerce - Multilingual - Products
I have added a product first in German with "Größe" as variant attribute and translated that to English with "Size". It shows correct data: sizes, stock, price. So in the sandbox it is ok.
What is causing the problems on kontaktil.com and on the dev system web.kontaktil.tirol
Primary Language? it is German there
Other Plugins? Stock management plugins?
please let me know your suggestions.
July 1, 2020 at 3:17 pm #6497077
Bigul
Thank you for the updates. We have released a new version of the WPML(4.3.16 series). Please upgrade to the latest version after a full site backup and check is there any difference in the result.
Please note, may you have to visit Plugins>>Add New>>Commerical tab and click on *Check for updates* button to get the upgrade links. This step will help us refresh the installer caches. Now WPML is releasing as a batch in the first few days of the release. So the upgrade notice will be visible only to a few of the customers. The count will increase each day. It will help us handle the situation easily incase of any bugs in the release.
If the issue exists, please fill the private details fields after a full site backup. I would like to access the admin area of your site for further checking.
Please check the following links for more details about our private information sharing policies.
Bigul
July 2, 2020 at 8:50 am #6501817
violaH-2
The products with custom attributes definition in ASCII characters does show correct stock information 1-2-3 (variants 10-20-30) in both languages
July 2, 2020 at 1:53 pm #6505385
Bigul
Thank you for the login information. It requires further checking. So please allows me to make a duplicator copy of your site using the Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server.
Bigul
July 2, 2020 at 3:14 pm #6506107
violaH-2
yes you can do this
July 3, 2020 at 7:35 am #6511195
violaH-2
i suppose, the coding of a German product custom attribute is different from a coding in English or other language
attribute_grose - English coding
attribute_groesse - German coding
Could kindly ask a developer about this?
July 3, 2020 at 9:42 am #6512915
Bigul
Thank you for the updates. This may be happening because of the misconfigurations in the Database. I made a copy of the site and working on it now. Will check about this with our second-tier team and get back to you as soon as possible. Please wait.
Bigul
July 6, 2020 at 2:31 pm #6531419
Bigul
The issue is existing after the initial debugging steps and the result is the same with the Dev version of WPML plugins. So I have forwarded the details to our second-tier team and waiting for their expert opinions. Please wait. We will get back to you soon.
Bigul
