You are using the WooCommerce Checkout Page Elements of the Rey theme and have activated the "Rearrange country, state & zip order?" option. However, it does not work and the phone field disappears when the WPML Multilingual & Multicurrency for WooCommerce plugin is activated. The features work fine once the WPML plugin is deactivated.
We have identified that the Rey Theme is not currently on our official compatibility list, which means it has not been fully tested with WPML. We recommend contacting the theme authors to have the theme reviewed through our Go Global program. This will help ensure full compatibility and proper testing with WPML.
The issue seems to be related to how the WooCommerce Multilingual (WCML) plugin alters the checkout process. WCML adds its own hooks and can trigger checkout updates more frequently, which the Rey theme's "Checkout Page Elements" feature may not handle correctly. This results in the custom field order not being reapplied and the fields not rendering in the custom layout when WCML is active. The necessary adjustments would need to be made on the Rey side to ensure compatibility with WooCommerce when WCML is active.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket.
Last updated by 3 months, 2 weeks ago.
Assisted by: Marcel.
