Last updated by Raja Mohammed 1 year ago.
May 3, 2019 at 8:49 am #3732377
kathleenV
Tell us what you are trying to do? There is a file that includes the strings in the database that takes over 180 MB
Is there any documentation that you are following? No, i already made a ticket for this issue before.
Is there a similar example that we can see? You can login to the website
What is the link to your site? hidden link
May 3, 2019 at 9:02 am #3732441
kathleenV
Hello, some additional info: this is the file in database:
c0me_icl_string_pages (181.3MB)
May 3, 2019 at 10:37 am #3733223
Raja Mohammed
Sorry that you are having performance issues with our plugin. I will help you with it.
Please share a snapshot copy of your site, You can use the Duplicator plugin to create a snapshot of the site and share the package link with me http://wordpress.org/plugins/duplicator/
I have enabled private fields for you to securely share the details.
Kind regards
Raja
May 3, 2019 at 12:44 pm #3734303
Raja Mohammed
Thanks for the access and the duplicator package. You can clean up the cache in strings table by executing the below query in MySql database one at a time. Let me know if you can perform this operation.
Before you proceed, Please secure a backup of your site.
TRUNCATE TABLE wp_icl_string_pages;
TRUNCATE TABLE  wp_icl_string_urls;
After truncating the table you will see some slowness in your site which is expected until WPML scans all the pages and URL. The performance will improve after some time.
If you need assistance, Let me know. I can help you with the operation. Just ensure you have a backup of your site.
Kind regards
Raja
May 3, 2019 at 12:46 pm #3734315
kathleenV
Hello
Since it's the first time after working lots of time with wpml, that i have this issue, i don't have the skills to perform this operation. Can i have some help please?
Thx already for taking a look
Kind regards
Kathleen
May 3, 2019 at 12:50 pm #3734323
Raja Mohammed
I hope you have a backup of your site. I am proceeding with the process.
Kind regards
Raja
May 3, 2019 at 12:51 pm #3734331
kathleenV
Yes i have a backup!
Thank you so very much, already!
Kind regards
Kathleen
May 3, 2019 at 1:02 pm #3734435
Raja Mohammed
I have executed the query, Please observe the changed. You will see some slowness but this will improve after some time. I would request you please check the performance after an hour or two and let me know if you still have any issues.
Kind regards
Raja
May 3, 2019 at 1:05 pm #3734465
kathleenV
Hello, thank you, i will do that.
I an previous ticket about the same issue, you college explained this method ( see screenshots attached). Is your solution the the same outcome but in another work around?
Kind regards
Kathleen
May 6, 2019 at 3:03 am #3744655
Raja Mohammed
Hi Kathleen
Hope you have a great weekend,
The solution I have attempted is not the same, I have attempted a database action to clean up any cache. The solution that was given to you is to prevent string registration which will help in most of the cases.
I hope everything is alright now, Please let me know the status of your issue.
Kind regards
Raja
May 6, 2019 at 10:20 am #3746973
kathleenV
Hello
Everything looks alright now! Thank you for that!
Is it necessary that i do the steps like your college showed, to prevent this from happening again?
I tried this earlier, but failed to do it right. Can you assist me on that one to, please?
Kind regards
Kathleen Verhelle
May 6, 2019 at 10:48 am #3747151
Raja Mohammed
If you encounter the issue again with the enormous size of the icl_string_pages table it's better to try the steps mentioned in my reply https://wpml.org/forums/topic/the-database-uses-200mb-for-icl-strings-same-problem-as-before/#post-3734303
Preventing string from registration will increase general performance which may not help when there is a need in database optimization.
I hope it's clear now 🙂
Kind regards
Raja
May 9, 2019 at 6:09 am #3773227
kathleenV
So its possible that the issue shows up again? There is no permanent solution?
Kind regards
Kathleen
May 9, 2019 at 11:23 am #3775593
Raja Mohammed
HI Kathleen,
This is probably a solution we have right now. I am not sure this will happen again or not. However, In case if it occurs please write to us.
We will be ready to help you in any case.
Kind regards
Raja
