This topic contains 18 replies, has 2 voices.
Last updated by Mladen Andrejic 4 years, 7 months ago.
Assigned support staff: Mladen Andrejic.
November 2, 2015 at 4:38 pm #737650
davidK-40
I am trying to:
URL of (my) website where problem appears: hidden link
I expected to see: all the blog section has mirror translate
Instead, I got: only English language while post is translate
Other problem I can see the language switch is not working properly .
November 3, 2015 at 2:11 pm #738434
Mladen Andrejic
Hello David,
I am sorry, but I don't understand the problem from your description. Can you please elaborate a little bit more about it?
- You can also write in German if it's easier for you.
November 3, 2015 at 2:27 pm #738453
davidK-40
Hello Mladen,
Thanks for your help , the problem I am facing is
1. The WordPress element is not translated when I switch the language. there for in German site I can see all the "POST COMMENT", "REPLY", "READ MORE " and etc is return with English.
2. Language switch problem . when I click on the land switch, the parameter is ?lang=de everything works fine but if the switch return ?lang=en it will be redirected to blog root and remove the parameter and lang will not change
3. When I am trying to change any post content , it will change the content of other langs too , I never had this problem with my old license .
here is the address of my blog , hidden link
If you need I can provide password and username for WordPress to check .
I will be highly appreciate of your help in advance .
Regards
AJ
November 3, 2015 at 3:26 pm #738533
Mladen Andrejic
First of all, can you please provide me the WPML Debug Informations. Here are the instructions : https://wpml.org/faq/provide-debug-information-faster-support/
According to our policy we can handle only one problem per ticket. Here I will help you with the buttons and give you complete instructions :
1. Go to WPML > Theme and Plugins Localization
2. Scan the theme (or plugin the strings come from) for strings
3. After the scan is finished, go to WPML > String Translation
4. There you should try to find the string - and translate it (make sure that the translation is marked as complete and saved)
5. If the string is not in the String Translation, you can try to add this string from "Translate texts in admin screens" (you can find it on the bottom of String Translation page)
6. When you get in the Admin Screens* and find the strings, then mark them and go to the bottom of that page and click "Apply"
7. After you click "Apply" wait for the confirmation message
* Admin Screens explanation : The concept of Texts in Admin Screens is to add the strings that are stored in the database, to be precise in wp_options table. So if the theme or plugin stores some strings inside wp_options table, you will be able to translate this string. You should find option_name and expand it, then add this string to ST.
// Here I will give you some tips and guidelines about other 2 problems that might help, so you don't have to open new tickets for this :
1. For language switch, please make sure that the page you are viewing has an English translation.
2. About content update - please make sure that your content is not set as duplicate. If it is set as duplicate you will need to use "Translate Independently" button for the translations.
November 3, 2015 at 3:57 pm #738571
davidK-40
I follow your structure but still I can see the button is not with german .
Could you please suggest me what should it do ?
Regards
AJ
November 4, 2015 at 8:35 am #739087
Mladen Andrejic
In order to be of a better help, I will need to request temporary access (WP-Admin and FTP) to your site.
You will find the needed fields for this below the comment area when you log in to leave your next reply like this hidden link .
// NOTE : Make sure that you have performed the backup before you let me access the site.
November 20, 2015 at 1:25 pm #751238
Mladen Andrejic
Can you please recheck the credentials you sent me? I get "Invalid username" error.
November 20, 2015 at 1:56 pm #751268
davidK-40
for FTP or for WordPress ?
November 20, 2015 at 2:18 pm #751296
Mladen Andrejic
For WP backend.
November 20, 2015 at 3:09 pm #751365
davidK-40
Username : // USER //
Password : // PASSWORD //
November 20, 2015 at 3:16 pm #751376
Mladen Andrejic
It looks like now password is not correct.
Can you please recheck this? I will enable private reply.
November 23, 2015 at 10:32 am #752379
davidK-40
Hi Sir ,
Could you please let me know if there is any new status regarding my request .
Many thanks
AJ
November 23, 2015 at 10:48 am #752399
Mladen Andrejic
Hello David,
Yes, I was juts looking the website. Turns out that "Post Comment" label that is located in theme file comments.php on line 86 :
'label_submit' => 'Post Comment',
is not localized, which means that WPML can't read it as a string ready for translation.
Please contact your theme developers and ask them to take care of the problem. Here you can find useful page for localizing the strings : https://wpml.org/faq/getting-string-translation-to-work/
// NOTE : Method 2 is since WPML 3.2 deprecated, please use wpml_register_single_string instead : https://wpml.org/wpml-hook/wpml_register_string_for_translation/
December 3, 2015 at 10:59 am #760451
davidK-40
I have problem with switch language . I use
hidden link for English
hidden link for Germany
For Germany is working, but for English which has been defined as default language sometimes is work sometimes is not work , additionally it will be remove the parameter of lang=en which count as temporary redirect 302 which is not good for our SEO propose . Could you please check and guide me to solve this issue as soon as possible.
Regards
AJ
December 3, 2015 at 1:05 pm #760586
Mladen Andrejic
When one of the languages is default it does not use language parameter at all. It will be on the main page.
If you have any further problems with this, please create new ticket as the original issue is resolved.
