Last updated by Bigul 1 year ago.
May 15, 2019 at 12:56 pm #3816619
enricoT-12
I am trying to:i want to edit variation in my variable product which we added before activating wpml. in new products i can add variation and variations also loading but not in all old products check attachment
[removed for security]
Please login in admin and open the below link there you will see the issue in variation tab
May 15, 2019 at 3:30 pm #3818351
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
Please try the following steps after a site backup and make sure the issue is existing or not.
1) Visit WooCommerce>>WooCommerce Multilingual
2) Choose *Attributes* tab
3) Select *Color* from *Select the attribute to translate* drop down box
4) Scroll down to the bottom of the screen
5) Click on *Synchronize attributes and update product variations* button
6) Wait till the process complete
7) Please do the same for *Size* attribute
Please check the attached images and let me know your feedback.
Bigul
May 16, 2019 at 5:43 am #3822059
enricoT-12
Thanks for your reply.
I have already done this as you mentioned above but still variations are not showing up , i need the solution asap.
May 16, 2019 at 12:38 pm #3825839
Bigul
Thank you for the feedback. Please try the following troubleshooting steps after a site backup and make sure the issue is existing or not.
1) Go to WPML>>Support page
2) Click on Troubleshooting link (blue link in the middle of the page)
3) In Troubleshooting page, choose *Products* and *Variations* from the drop-down field and click on *Synchronize posts taxonomies* button. Please check the attached image for more details.
4) Then please click on the following options of the *Clean up* section. Wait for confirmation of processing after each one.
- Clear the cache in WPML
- Fix element_type collation
- Set language information
- Fix WPML tables collation
- Fix terms count
- Fix post type assignment
- Recreate ST DB cache tables
Bigul
The topic ‘[Closed] The variations of woocommerce products not showing’ is closed to new replies.
