You are experiencing an issue with the String Translation table after performing a WPML reset. This problem is not currently affecting your site's operation but could become critical in the future.
If you have not yet completed any translations, we recommend resetting WPML again and reconfiguring it. Please follow these steps:
1. Navigate to WPML → Support and click on the Troubleshooting link.
2. In the Reset section of the Troubleshooting page, check the "I am about to reset all translation and language data" box. Then, click the "Reset and deactivate WPML" button. For detailed instructions, visit WPML Reset Documentation.
Before making any changes, ensure that you back up your database.
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML Support Forum.
Last updated by Andrey 7 months, 1 week ago.
Assisted by: Andrey.
April 18, 2025 at 10:38 pm #16948329
Maximilian Wellner
I did a WPML reset and now get an error related to the String Translation table. The issue is not affecting the site currently but could become critical. The WPML support team knows how to fix it. I was trying to resolve this by adding a message in the relevant support thread. The issue can be seen at: hidden link.
There is a problem with the String Translation table in your site. This problem is not causing a problem running the site right now, but can become a critical issue in the future. WPML support team knows how to fix it. Please add a message in the relevant support thread and we'll fix it for you.
There is a problem with the String Translation table. This problem is not causing a problem running the site right now, but can become a critical issue in the future.
How can I fix the String Translation table issue after a WPML reset?
April 20, 2025 at 9:28 am #16949593
Andrey
WPML Supporter since 06/2013
Thank you for reaching out to WPML support.
If you have not yet completed any translations, I recommend resetting WPML one more time and reconfiguring it.
Follow these steps:
https://wpml.org/documentation/getting-started-guide/language-setup/deleting-languages-and-plugin-data-by-doing-a-wpml-reset-on-your-site/#step-3-do-the-wpml-reset
Before making any changes, please ensure that you back up your database.
April 20, 2025 at 12:44 pm #16949841
Maximilian Wellner
Still happening:
We have detected a problem with some tables in the database. Please contact WPML support to get this fixed.
Table 'dfukpczkuu.i0deobxc2xicl_strings' doesn't exist
Array
[language] => en
[context] => admin_texts_rank-math-options-titles
[gettext_context] =>
[domain_name_context_md5] => 5df40f23b55a6185b7f4ff4a0f0dcd4e
[name] => [rank-math-options-titles]title_separator
[value] => -
[status] => 0
[translation_priority] => optional
[allow_empty_value] => 1
Please can you check?
April 22, 2025 at 1:24 pm #16955426
Andrey
Thank you for your feedback and for providing more details.
Occasionally, such warning messages can appear as false positives and may get stuck. To resolve this issue, please follow these steps:
1. Click the small 'x' icon on the warning message to attempt to remove it.
2. Refresh the dashboard to see if the warning message still appears.
If the message disappears, everything is likely in order. If the issue continues, please let me know so we can investigate further.
If the issue persists, please check this errata https://wpml.org/errata/missing-_icl_strings-_icl_string_translations-data-tables/ and follow the instructions carefully.
For more detailed information, please refer to the following documentation:
https://wpml.org/faq/how-to-deal-with-error-messages-about-a-broken-table-that-needs-fixing/#problem-with-some-tables-in-the-database
April 24, 2025 at 10:21 pm #16966443
Maximilian Wellner
I tried it without success, please, check my site and get this fixed for me.
April 25, 2025 at 8:07 am #16967301
Andrey
If you have no translations yet, can I reset WPML again if needed?
April 25, 2025 at 1:28 pm #16968800
Andrey
Can you configure WPML and test it? It should work fine. Let me know how it goes.
May 1, 2025 at 3:06 pm #16986825
Maximilian Wellner
well I cant even click on continue here, please check
May 1, 2025 at 6:12 pm #16987216
Andrey
I've looked at this, and it's unusual.
Can you temporarily disable all plugins except WPML and switch to a default theme? Can you finish the wizard then?
Please backup your database before making any changes.
May 3, 2025 at 8:20 pm #16992410
Maximilian Wellner
now it worked, but now I set a home page and it errors, please check hidden link and hidden link
New threads created by Andrey and linked to this one are listed below:
https://wpml.org/forums/topic/split-i-set-a-home-page-and-it-errors/
May 5, 2025 at 1:09 pm #16996428
Andrey
now it worked, but now I set a home page and it errors, please check hidden link and hidden link;
That it could be something else, I opened a new ticket to answer your new question. This will also help other users with similar issues find solutions when searching the forum. I will assist here: https://wpml.org/forums/topic/split-i-set-a-home-page-and-it-errors/
