Client gets this messages in WPML:
"There is a problem with the String Translation table in your site. This problem is not causing a problem running the site right now, but can become a critical issue in the future. WPML support team knows how to fix it. Please add a message in the relevant support thread and we'll fix it for you."
In 'Themes and Plugin Lokalisierung':
"Themes und Plugins nur mit WPMLs String Translation übersetzen (Keine .mo-Dateien laden) WPML kann .mo-Dateien aufgrund technischer Probleme in der String Translation-Tabelle nicht ersetzen. Das WPML-Supportteam weiß, wie sich das lösen lässt. Bitte fügen Sie eine Nachricht im relevanten Support-Thread hinzu, dann beheben wir dies für Sie."
The first notice shows up when the String Translation tables are not created correctly, so the problem with the database is solved re-installating WPML.
To get rid of the notice you need to do remove a key from the table wp_options. If your WordPress is using another table prefix it will be something like ..._options.
The key you need to remove is this:
wpml_string_table_ok_for_mo_import
You can check if it exists by running a query similar to the following, in Adminer or phpMyAdmin (please use your own table prefix if you are not using wp_options):
SELECT * FROM `wp_options` WHERE `option_name` LIKE 'wpml_string_table_ok_for_mo_import'
Once you have seen this key, you should remove it and visit the front-end of your site.
If you visit then the WPML -> Theme and plugin localization page and there is no notice - then you have successfully completed the procedure.
Relevant Documentation:
Last updated by benjamin 2 years, 2 months ago.
Assigned support staff: Cristina.
December 18, 2017 at 12:24 pm #1460270
benjamin
hello WPML
it says:
and in 'Themes and Plugin Lokalisierung':
I set back "RESET", deacitvaed WPML and stared all over again, now there are no more Database Error on debug-mode.
But the issue above still remain.
best regards, Ben
December 19, 2017 at 9:33 am #1461199
Cristina
Hello Benjamin.
thanks for contacting us on this.
The first notice shows up when the String Translation tables are not created correctly, so the problem with the database was solved with your re-installation of WPML.
Once you have seen this key - you should remove it and visit the front-end of your site.
Kind regards,
Cristina
December 19, 2017 at 10:34 am #1461324
benjamin
thanks Cristina, very helpful
