Problem: The blog page title is set within the theme options. How can I translate that string? It appears in the breadcrumb in the original language.
Relevant Documentation: https://wpml.org/documentation/getting-started-guide/translating-theme-options/
Last updated by francoisP-2 3 years, 10 months ago.
Assigned support staff: Otto.
January 19, 2018 at 4:28 pm
francoisP-2
Individual posts are OK, but the main posts page is not, title & breadcrumbs show in English, should be in French.
Blog page name (English): News (hidden link)
Blog page name (French): Nouvelles (hidden link)
See pictures.
François
January 21, 2018 at 7:23 pm #1491213
Otto
Hello François,
Please apologie for the delay in answering. This is not usual in this forum. I'll take care of your ticket and reply time will be shorter from now.
Can you please update WPML and its add-ons to their latest version and let me know if the issue persists after that? Please back up your site before updating.
If it does, it looks like a compatibility. So, before moving forward I suggest checking these alternatives:
https://wpml.org/documentation/getting-started-guide/site-navigation/customizing-wpml-navigation/
Let me know if it helped, please.
Kind Regards,
Otto
January 21, 2018 at 7:43 pm #1491226
francoisP-2
Hi Otto,
The issue persists after the update.
This is a template from Template Monster and should be "WPML ready".
What's causing this?
François
January 21, 2018 at 9:40 pm #1491292
Otto
Hello François,
I am not sure, maybe a new compatibility issue. It needs further investigation.
Is it possible for you to share a copy of the last version of the theme, so I can try it locally and investigate further?
I'll set next reply as private, so you can share a download link safely.
Once the issue is solved I'll delete the files.
Kind Regards,
Otto
January 22, 2018 at 3:33 pm
January 22, 2018 at 6:50 pm #1492629
Otto
Please apologize for the misunderstanding, but you provided the DB file and I need to test the theme.
The form asks you for the DB, I am truly sorry I didn't explain this before.
I am enabling a new private reply. Please, upload the theme files and paste in the body of the reply a link so I can download it and test it locally.
If you prefer, I can access your site and get it.
Maybe I'll need to replicate your site locally. For this, I’ll need to temporarily install a plugin called “Duplicator” on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok for you.
** IMPORTANT **
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this:
Kind Regards,
Otto
January 22, 2018 at 9:06 pm #1492816
francoisP-2
Please access the site to get it. I supplied all access info when I opened the ticket.
François
January 23, 2018 at 12:22 pm #1493746
Otto
Hello François,
Thanks, I am sorry I missed that.
To solve the issue, please add the following to WPML -> Translation Management -> Custom XML Configuration:
<wpml-config>
  <admin-texts>
    <key name="theme52702">
      <key name="blog_text"/>
    </key>
  </admin-texts>
</wpml-config>
Then, go to WPML > String Translation and you will find the string "News" available to translate under the domain "admin_texts_theme52702"
Just translate it and it will show on the front end.
Let me know if this helps, please.
Kind Regards,
Otto
January 23, 2018 at 5:37 pm #1494325
francoisP-2
It works!
Thank you very much Otto!
François
