Toolset CPT with custom repeatable fields and WPML translation issues.
We found a solution that works perfectly: https://toolset.com/forums/topic/toolset-cpt-with-custom-repeatable-fields-and-wpml-translation-issues/
Last updated by Itamar 9 months ago.
August 26, 2019 at 8:33 pm #4461293
Andreas K.
Hi
I am using Toolset for a CPT on a site along with WPML with two languages and Toolset Views with a search function to show the CPT posts as results.
The CPT has custom fields and some of them are repeatable fields.
And this is where my problem is.
As I have two languages and the CPT posts are going to be written in language 1 first and published and then slowly translated one by one into language 2, I need the views/search to only show the CPT posts for language 1, when that language is selected on the language selector in the menu, and only show the CPT posts for language 2, when that one is selected.
For this I would select “Translatable - only show translated items” for the CPT in the WPML settings, and not “Translatable - use translation if available or fallback to default language”.
But this cannot be done when using repeatable fields?
I am told in the Toolset repeatable customs fields when editing one of the CPT posts, that I need to enable the “Translatable - use translation if available or fallback to default language” setting to access/edit the field.
I seem to have read somewhere on either of your sites something about this also.
It is very unfortunate if this cannot be done as it makes the website work counterintuitive for the users/editors who do not wish to publish/show language 1 posts on language 2 as the fallback setting will it do.
I just switched from Polylang because of conflicts with Toolset Views, and really like WPML, but Polylang had no problem with separating the two language posts on the views though.
What to do? And why is this so?
The funny thing is, that when I do use the setting “Translatable - only show translated items” is does work on the frontend - only the selected language posts are show on the views - but I am just not allowed to edit the CPT fields in the backend, where I get the error (se the attached image).
If I have to use the “Translatable - use translation if available or fallback to default language”, there must be someway to hide the second language on the views, to make the views only show one/the active language??
Both Toolset and WPML is from the same company, as I understand, so I hoped, that they would work perfectly together…
August 28, 2019 at 7:16 am #4471537
Itamar
Hi.
Can you please describe in details how I can replicate this issue?
Please tell me the steps that I should take to also see this issue on my WPML and Toolset test site. It would be helpful if you write to me like this: Do 1. 2. 3. and so on.
Sometimes screen-shots illustrating what you mean may go a long way to clarify what words fail to transmit, so if you like, make use of “upload an image” below the comment area.
Itamar.
August 30, 2019 at 10:06 pm #4489315
Andreas K.
Hi Itamar
I am trying to find a solution with the Toolset team, so I will get back to you, if it is unsuccessful.
Best,
August 31, 2019 at 1:03 am #4489471
Andreas K.
Hi
September 1, 2019 at 6:10 pm #4492929
Itamar
Great, I'm glad that it is solved now!
Good luck with your web projects 🙂
Itamar.
