Last updated by gregorN 11 months, 4 weeks ago.
Assigned support staff: Noman.
August 19, 2019 at 12:47 pm #4416065
gregorN
Hello
I am trying to edit the translation of posts and pages without the translation management.
I found another help entry asking the same question (https://wpml.org/forums/topic/disable-the-wpml-editor/) but I cannot find the option described as solution in this post.
There is no option 'Create translations manually' in WPML > Settings > How to translate posts and pages.
Did anything change with updates of the plugin in the meantime?
Heiko
August 19, 2019 at 12:54 pm #4416161
Noman
Thank you for contacting WPML Support. We have moved manual translation option inside the page editing screen. When you are editing a page, there is a new option "Use WPML's Translation Editor" -- please see attached screenshot.
Click it and you are prompted if you want to make this change site-wide or for one page/post only.
Here is doc for more details:
Thank you
August 19, 2019 at 1:36 pm #4416513
gregorN
