This topic contains 65 replies, has 2 voices.
Last updated by Lauren 10 months, 1 week ago.
June 6, 2019 at 7:03 am #3966189
alexanderA
Hello. I have used WPML to translate my site into French and Chinese. My theme has a custom post type named "Agents." The archive page for one of these posts is here: hidden link Towards the bottom of that page is a section "My Listings" and it displays a list of several posts--all of these posts are of type "property," have have this particular Agent assigned to it.
My issue is that the French and Chinese versions of this page do not display the "My Listings" section at all. The PHP code governing the page seems to think there are no properties assigned to this agent. The French and Chinese pages are here:
How can I resolve this? I have already translated the "property" posts into French and Chinese. Do I somehow need to translate this "Agent" into French and Chinese?
June 6, 2019 at 1:51 pm #3969659
Lauren
I believe you will need to also translate the agents in order for this to display. Please go to WPML -> Settings and scroll down to the post types section. Here, you can set the Agents to Translatable. Please let me know if that resolves the issue.
June 9, 2019 at 12:48 pm #3983091
alexanderA
OK I opened WPML -> Settings -> post types and see that 'Agents' is already set to "Translatable - only show translated items." Thoughts?
June 10, 2019 at 1:48 pm #3987793
Lauren
Have you translated the agents and then assigned the translated properties to the translated agents?
June 10, 2019 at 2:20 pm #3988101
alexanderA
It looks like each of the Agent posts have been duplicated into both French and Chinese (the two languages on my site other than English). The French and Chinese versions are duplicates--they are not set to 'translate independently.' In light of that, what steps should I try?
Furthermore, I have already translated all of my properties into French. But when I open the French version of a property for editing, the assigned agent is not set. Rather, it is set to 'Disable agent.' My educated guess is that when I duplicated all of the properties into French, I may have done so *before* translating the agents. So the newly created French properties had their 'assigned agent' reverted to the default 'Disable agent,' rather than the correct agent. What do you think of that reasoning ? If it is sound, how can I best resolve it?
June 10, 2019 at 5:02 pm #3989005
Lauren
Let's try this. Please go to WPML -> Settings and in the custom field section, click "Show system fields". Now look for the field for the agent assignment. Try setting this to Translate or Copy, then save the original property and resave the translation. After that, does it assign the agent correctly? Another option is to use manual translation and assign the agent using the traditional WordPress editor.
Please let me know if that resolves the issue for you.
June 11, 2019 at 9:15 am #3993483
alexanderA
OK I partially followed your instructions. I opened WPML -> Settings and in the custom field section, clicked "Show system fields." I am now on the step,
Which field is this exactly? After I showed system fields, there were many many fields (17 pages worth). So in the search box, I typed 'agent.' It then filtered out most results, and left me with 11 choices (see attached screenshot). Would it be the 'ale_assigned_agent' field?
June 11, 2019 at 1:27 pm #3995713
Lauren
Yes, I believe that ale_assigned_agent would be the correct field. Please try setting that to Copy or Translate and let's see if that resolves the issue.
June 12, 2019 at 7:23 am #4001069
alexanderA
OK. It is already set to 'Copy.'
June 12, 2019 at 2:32 pm #4005327
Lauren
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
June 13, 2019 at 1:49 pm #4013441
Lauren
Thanks. I found that you will need to manually assign the agent in the translated property. This means that you need to click "Translate Independently" and then select the agent from the drop down. As you can see, I tested this on the following property and now it shows on the translated agent page: hidden link
I would suggest asking the author which field controls this, and perhaps the author can add in the next update the wpml-config.xml file that will automatically assign this for you.
June 13, 2019 at 2:19 pm #4013681
alexanderA
OK thanks for the info. Here are my follow-ups.
>> You will need to manually assign the agent in the translated property. This means that you need to click "Translate Independently" and then select the agent from the drop down.
OK. But my site (my live site, not my dev site) already has ~500 properties translated independently into both French and Chinese. All of have 'Disable agent' set as the 'agent.' So manually changing each one at this point is a very tedious and time consuming task. Is there any way around that? To remind you, the English version of each property has the correct 'agent' assigned--it is the FR and CN versions that incorrectly have 'Disable agent' assigned.
The plugin authors are no longer in business, so it is unfortunately not possible to contact them 🙁
June 13, 2019 at 2:35 pm #4013929
Lauren
I'm afraid without knowing which field would need to be registered in the wpml-config.xml file, there is no way to determine how to set that field to copy. And without being able to set it to copy, I don't know of another way to automatically change the setting for the translated posts. I suppose you could try to find the value in the database and then run a sql query to change the settings for your secondary languages, but the details for that would be outside of the scope of WPML support.
If you need further assistance, I can suggest you consider contacting one of our certified partners from this link: http://wpml.org/documentation/support/wpml-contractors
June 13, 2019 at 3:00 pm #4014129
alexanderA
Which 'field' are you referencing here? I thought we already determined that the 'ale_assigned_agent' field was set to 'copy?'
June 13, 2019 at 3:59 pm #4015291
Lauren
That was my guess, but since it's not working, I don't know how the theme is handling that field or even if it is the correct field to set to copy. That's why unfortunately we would need the author's assistance. I scrolled through the Admin Texts looking for theme options that could be set, but I honestly don't know how the theme works, so I'm afraid we are stuck. We simply need to know where that option is stored and how it can be copied. I would have assumed that setting the assigned agent to copy or even translate would work, but I tested both and it doesn't.
If you would like to send me a copy of your theme, I will be happy to install it on a fresh site and try to reproduce, which will allow me to determine if it is the theme that is causing the issue, or perhaps a conflict or setting in your site particular.
