This topic contains 65 replies, has 2 voices.
Last updated by Lauren 1 year ago.
July 30, 2019 at 1:17 pm #4307935
alexanderA
OK got it. But what about my new issue. Namely, on both sites (dev and live), if I create a new property, and assign it the agent of 'Craig Beechey,' it appears on the English agents page for Craig Beechey (i.e. hidden link). But it does not appear on the French page for Craig Beechey (hidden link). I was under the impression the fix we implemented would ensure that all new properties would display as expected.
July 30, 2019 at 2:44 pm #4308621
Lauren
This happens after you translate the property to French, is that correct? if you manually edit the French translation, what do you see in the assigned agent drop down?
I thought this had been resolved but if you can confirm the above is happening after translating the property, I'll send this back to our 2nd tier for additional debugging.
July 31, 2019 at 9:53 am #4313391
alexanderA
So to be clear, on my site I have custom code that does the following. Whenever a new post of type 'property' is created in the default language (English), it is also *duplicated* into French and Chinese. So what I have done is create a new English post, and set the agent to 'Craig Beechey.' After that new post is created, the FR duplicate is automatically generated. If i open that, the 'agent' field is set to 'disable agent.' Maybe something about the duplication process isn't copying this field?
I thought I had confirmed it too. I remember creating a test property on my dev site and confirming that. But the issue is definitely occurring now.
July 31, 2019 at 1:05 pm #4314645
Lauren
Okay, my developers took another look and updated the code snippet. Please go to your theme's functions.php file and replace the code you earlier added with the following:
function translate_agent_id($post_id) {
    $meta_key = 'ale_assigned_agent';
    $agent_id = get_post_meta($post_id, $meta_key, true);
    if ($agent_id)
        update_post_meta($post_id, $meta_key, apply_filters('wpml_object_id', $agent_id, 'agents', true));
add_filter( 'save_post', 'translate_agent_id', 9999 );
function translate_duplicated_agent_id( $value_to_filter, $target_language, $meta_data ) {
    if ($meta_data['key'] === 'ale_assigned_agent') {
        return $value_to_filter = apply_filters('wpml_object_id', $value_to_filter, 'agents', true, $target_language);
    return $value_to_filter;
add_filter( 'wpml_duplicate_generic_string', 'translate_duplicated_agent_id', 10, 3 );
Then resave translated properties. I tested this on my test site and it is now working. If you create a new property and translate it, it should work fine as well. Please let me know the results.
August 1, 2019 at 6:44 am #4319053
alexanderA
OK thanks for that. I added the code to my dev site, tested it with a new post, and the issue seems to have gone away. Funny thing though, on my live site, since we last spoke, 2 new properties were created. Let me start going through my live site and updating all ~600 posts, to slowly resolve the issue there. Can we keep this ticket open for a week or two while I do that, just in case I run into related issues?
August 1, 2019 at 12:09 pm #4321375
Lauren
Sure, we can keep this open while you continue saving the translations. Let me know if you run into anything.
