Last updated by hendA 1 year, 1 month ago.
Assigned support staff: Noman.
August 7, 2019 at 4:29 pm #4356811
hendA
I have some problems concerning posts in the translated version:
1- Post titles are aligned right in the main Posts page
2- In the Recent Posts widget posts dates are not showing correctly although titles are aligned right
August 7, 2019 at 6:38 pm #4357451
Noman
Thank you for contacting WPML Support. You can fix this issue by adding below CSS in WPML >> Languages >> Additional CSS section:
:lang(ar) .post_meta, :lang(ar) .blogpost .archives_title{
	text-align:right !important;
And it will look as in the attached screenshot. Please let me know if this resolves your issue or you need further assistance with this issue.
August 15, 2019 at 7:43 am #4399309
hendA
Thank you, this piece of code solved the problem for this section.
But there is another problem that the comment icon appearing over the date
Here is the link for the page.
and here is a screenshot of the problem
August 18, 2019 at 3:12 pm #4412437
Noman
I just visited your site and it seems comment icon is aligned correctly as you can see in the attached screenshot, have you been able to correct your problem?
Thank you
August 19, 2019 at 9:17 am #4414829
hendA
I opened another ticket with this issue and it has been solved with a piece of code.
Thank you
