Last updated by Bruno 1 year, 1 month ago.
April 12, 2019 at 4:10 pm #3600463
selimU-2
I am trying to:
Translate taxonomies (product categories) via WPML's taxonomy translation.
Until now it worked well, i was able to translate english taxonomies to French, Italian and Spanish.
Im doing this so that I can import products into taxonomy via WP All Import. Taxonomies has to be translated first.
However, when I am trying to translate the taxonomies in Swedish or Norwegian, it seems okay, until i leave the Taxonomy translation page. When I come back, the translation disappears since there is + icon instead of a pencil icon. However, the taxonomies do show up in Product categories in Swedish and Norwegian. So it seems like the taxonomies are being created, but not linked...
April 12, 2019 at 11:02 pm #3602361
Bruno
Thank you for contacting us. I noticed you are using some old plugins. Please, you could update all your plugins and check if the problem persists.
If the problem persists, I'll need to request temporary access (wp-admin and FTP) to your site - preferably to a test site where the problem has been replicated if possible - in order to be of better help.
Note:
*** Please, can I install the Duplicator plugin (or All in One Migration) to make a copy of your site and install it on my test environment? This will help me debug the problem.
*** Note: Please make a full backup of your site.
Privacy and Security when Providing Debug Information for Support: https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/
April 15, 2019 at 11:10 pm #3616871
Bruno
Thank you. I did a copy of your site. I will install it on my test environment and soon I will contact you.
About your second question, may I kindly ask you please to open a new ticket for your new question? According to our guidelines, only one issue per topic is allowed. Also, this will also help other users with similar problems find solutions when searching the forum.
April 26, 2019 at 1:26 pm #3690975
selimU-2
Its been a while and I havent received any feedback?
April 26, 2019 at 5:54 pm #3692707
Bruno
My sincere apologies for the delay. This is a small bug that is causing in WPML and it will be fixed in a future release.
As a workaround, please, inside the wp-config.php file, add this line:
define( 'WPML_TAXONOMY_TRANSLATION_MAX_TERMS_RESULTS_SET', 5000 );
E.g.
This bug only happens when there are many taxonomies (+1000). Our developers are already aware of this problem and this will be fixed in a future release.
Please, could you verify if following the above steps, the problem is fixed?
