Translated Products Fail to Appear. I also get this error "Some taxonomies in your site are forced to be untranslatable. This is causing a problem when you're trying to run a multilingual WooCommerce site."
The error you receive ("Some taxonomies in your site are forced to be untranslatable. This is causing a problem when you're trying to run a multilingual WooCommerce site.") is caused by the fact that all the taxonomies on your site are currently set as "Not Translatable".
They need to be set as "Translatable" and you can do that by following the steps below:
1. Go to your WP Dashboard 2. Go to WPML > Settings 3. Scroll down till you get to the section called "Taxonomies Translation" 4. Set the ones you want as "Translatable" and then click the blue "Save" button
You will also see by scrolling up that from this settings page you can set as "Translatable" many things like "Custom Fields", "Custom Term Meta" or "Post Types".
Relevant Documentation:
https://wpml.org/documentation/getting-started-guide/translating-post-categories-and-custom-taxonomies/ https://wpml.org/documentation/getting-started-guide/translating-custom-posts/
Last updated by luizS-2 1 year, 8 months ago.
Assigned support staff: Mihai Apetrei.
September 27, 2018 at 2:15 pm
luizS-2
I am trying to: Ensure the right courses appear in the right fields on the course listings page. I am currently using a staging site.
Link to a page where the issue can be seen: Can I provide access to our staging site?
I expected to see: Each course section is fully populated with the relevant products
Instead, I got: A no events found message appears instead. The following text reads in the builder above "Some taxonomies in your site are forced to be untranslatable. This is causing a problem when you're trying to run a multilingual WooCommerce site."
September 28, 2018 at 10:50 am #2773298
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
The error you receive ("Some taxonomies in your site are forced to be untranslatable. This is causing a problem when you're trying to run a multilingual WooCommerce site.") is caused by the fact that all the taxonomies on your site are currently set as "Not Translatable" (I will also attach a screenshot so that you will see what I mean).
Here is also some very helpful documentation regarding the process of translating taxonomies and custom post types:
Let me know if this solved your issue.
October 1, 2018 at 12:56 pm #2778189
luizS-2
Thanks Mihai, that seems to have resolved it!
