I translated all my products to 2 other languages, but they are not visible on the eshop when I switch to those languages.
I've checked things on your site and found out that this problem happens because the translated products are in the 'Draft' status. You can fix this issue by changing the status of the translated products.
1. Edit the translated products with the WordPress editor. You can do it from the list of all the products - Products -> All Products in each language. You can also get to the WordPress editing screen of the translated product while changing the language flag while you are on the editing screen of the original product.
2. While on the translated product screen, press the Publish button. Please see the attached screenshot publish-product-button.jpg. Do not change any other setting while on this screen!
For example this hidden link
Can you please advise?
I can see that when I try the link, you shared with us, I can not switch to the other languages. The Language Switcher is not working.
Is this the problem that you experience as well?
As a first step in debugging this issue, please deactivate the W3 Total Cache plugin you are using. Then check if the problem persists. This way, we will illuminate any caching issue.
Nothing changes after deactivation. I have the same problem changing the language as you. However when I am logged in to WP, I can change the language on that product page. But the url is hidden link
I've checked things on your site and found out that this problem happens because the translated products are in the 'Draft' status. If you go to Products - > All Products, you will see 29 (now only 28) products in the draft status. Please see the attached screenshot products-en-cz-draft.jpg.
In WPML -> Settings -> Translated documents options, I can see that the option 'Same as the original document' is selected. Please see the attached screenshot same-as-original.jpg. It is not clear why the translated products are in the draft status. This might be because the original products were in the draft status when the translation was received. Or for another reason, I'm not aware of.
In any case, it is easy to fix this issue by changing the status of the translated products. I tried it with one product on your site, and it worked. I tried it with this product.
When I switch to English, I get the translated product here.
Please see the attached screenshot en-product-ok.jpg.
Here is how you can fix this issue.
Now the translated products will work as expected.
Please let me know if you have further questions or mark this ticket as resolved.
Itamar.
This ticket is now closed. If you're a WPML client and need related help, please open a new support ticket.
