Last updated by martaS-10 1 year, 1 month ago.
April 3, 2019 at 6:34 am #3522801
martaS-10
Translate these two sentences:
"YOUR SHOPPING CART IS EMPTY
We invite you to get acquainted with an assortment of our shop.Surely you can find something for yourself!"
no
no
April 3, 2019 at 7:29 am #3523059
Raja Mohammed
Welcome to our forum.
Please clarify from where you have added the text? Is it from the theme options?
Did you try searching the string in WPML > String translation table, Were you able to find the string there?
Please check the translation steps mentioned in the xstore documentation
Does it help?
Let me know the results. If you are still stuck please share temporary access to the site. I have enabled the private reply for you to securely share the details.
Kind regards
Raja
April 3, 2019 at 6:30 pm #3529773
martaS-10
The text is automatically generated. The 'cart' page only has "[woocommerce_cart]" in it.
I've scanned the theme/plugin files, found the strings in the 'String Translation' part and translated them, and marked the translation as complete.
It has worked for literally all the other strings I've found and translated but not for these two... Is there like a 'cache' for translated strings and it hasn't been updated or something?
April 4, 2019 at 6:58 am #3532681
Raja Mohammed
Thanks for the information, If you can see the string in ST tables then it should be a cache issu.
Try clearing the String Translation cache. from WPML > Support > Troubleshooting (check screenshot)
In the troubleshooting page,
- Click "Clear the Cache in WPML"
- Scroll down, click "Recreate ST DB cache tables"
Please increase the PHP Memory Limit (your current setting is 40M).
/** Memory Limit */
Kind regards
Raja
April 5, 2019 at 6:48 am #3540977
martaS-10
Did "Clear the Cache in WPML", got alert pop-up saying 'Done',
Did "Recreate ST DB cache tables", got alert pop-up saying 'Done'.
Also increased the PHP Memory Limit.
The strings still are not appearing translated.
April 5, 2019 at 2:04 pm #3544759
Raja Mohammed
Thanks for trying all the steps. Please share temporary login details, Let me check this for you, I have enabled the private fields for you to securely share the details.
Kind regards
Raja
April 9, 2019 at 9:20 am #3564807
Raja Mohammed
the string is coming from the theme option. I have added the text to string translation by adding the below config to WPML > Settings > Custom xml Configuration
<wpml-config>
    <admin-texts>
        <key name="et_options">
            <key name="empty_cart_content"></key>
        </key>
    </admin-texts>
</wpml-config>
Please go to WPML > String translation, Select the domain admin_texts_et_option You can see the cart text available for trasnaltion.
I hope this solves your issue.
Kind regards
Raja
April 9, 2019 at 2:33 pm #3568073
martaS-10
