This topic contains 4 replies, has 3 voices.
Last updated by Yvette 3 months, 2 weeks ago.
May 27, 2020 at 3:01 pm #6230549
kitC
Dear sir,
I am using Checkout Field Editor (Checkout Manager) for WooCommerce by By ThemeHigh.
I have created "wpml-config.xml" below. BTW ... I can't found the string translation of the sub key name "billing_identity", "billing_others", "billing_year" & "billing_major".
I can translated sub key "additional_remarks" seccussfully.
I also want to translate the sub key"billing_identity" options too.
Could you help to take a look my coding that is something wrong??
========== My Code below ===========
<wpml-config>
<admin-texts>
<key name="wbs_config">
<key name="rules">
<key name="*">
<key name="meta">
<key name="title"/></key>
</key>
</key>
</key>
<key name="wc_fields_additional">
<key name="additional_remarks">
<key name="label"/>
<key name="placeholder"/></key>
</key>
<key name="billing_identity">
<key name="label"/>
<key name="options"/></key>
</key>
<key name="billing_others">
<key name="label"/>
</key>
<key name="billing_year">
<key name="label"/>
</key>
<key name="billing_major">
<key name="label"/>
</key>
</admin-texts>
</wpml-config>
Cheers
Kit
May 29, 2020 at 9:16 am #6247705
Bruno Kos
While you are waiting for one of my colleagues to take this ticket and work on it, let me provide you with first debugging steps or if I can perhaps help with the issue quickly.
Can you try generating your XML like this?
https://wpml.org/documentation/related-projects/wpml-compatibility-test-tools-plugin/#how-do-i-generate-language-configuration-files-using-multilingual-tools
So try finding all of your fields within wc_fields_additional.
Specifically using this:
https://wpml.org/wp-content/uploads/2016/04/set-admin-text-to-be-translatable-768x347.png
You can get the plugin here:
Bruno Kos
May 29, 2020 at 9:49 am #6248193
kitC
Hi Bruno Kos,
Sorry ... I think I have something wrong to you.
I have customized XML configuration. WPML > Setting > Custom XML configuration.
<wpml-config>
<admin-texts>
<key name="rules">
<key name="*">
<key name="meta">
</key>
</key>
</key>
<key name="label"/>
</key>
<key name="label"/>
</key>
<key name="label"/>
</key>
<key name="label"/>
</key>
<key name="label"/>
</key>
</admin-texts>
</wpml-config>
BTW ... I can't found the string translation of the key name "billing_identity", "billing_others", "billing_year" & "billing_major".
I can translated key "additional_remarks" seccussfully.
I also want to translate the key "billing_identity" options too.
Cheers
Kit
May 31, 2020 at 3:11 pm #6260643
Yvette
Hello
I´ll be helping you.
1. ) Temporary Access to your system
Please provide access to your system (wp-admin and ftp) so that I can further investigate this particular problem. The fields to provide this data are included in a private section that I will open for your next response. You can find it above the comments area. The information in this private section is only visible between WPML Support and you.
2. Please provide navigation steps or a URL for me to see the untranslating strings on your frontend.
June 2, 2020 at 8:22 am #6271695
Yvette
I added the following to your WPMl > Settings > Custom XML Configuraiton tab.
 <key name="wc_fields_billing">
      <key name="billing_first_name">
        <key name="label"/>
      </key>
      <key name="billing_last_name">
        <key name="label"/>
      </key>
        <key name="name"/>
        <key name="label"/>
        <key name="options">
          <key name="ccs"/>
          <key name="ccts"/>
          <key name="cca"/>
        </key>
      </key>
        <key name="name"/>
        <key name="label"/>
      </key>
        <key name="name"/>
        <key name="label"/>
      </key>
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_company">
        <key name="label"/>
      </key>
      <key name="billing_country">
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_address_1">
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_address_2">
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_city">
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_state">
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_postcode">
        <key name="name"/>
        <key name="label"/>
      </key>
      <key name="billing_email">
        <key name="label"/>
      </key>
    </key>
The strings are now registered for translation. I hope this works for you.
