This topic contains 2 replies, has 3 voices.
Last updated by Bigul 1 year, 1 month ago.
June 4, 2019 at 2:20 pm #3952585
johannV-2
On my website you can add Woocommerce products to a wishlist. In the wishlist the following code is showing the products description:
<div class="atlist__item__description"><?php echo adventure_tours_get_short_description( $item_post ); ?></div>
Depending on the language some products in the wishlist show the description and some dont as you can see in the attached screenshots.
Why is that and how to fix it?
To get an idea of the problem you can add the following products to your wishlist and change languages in the footer:
Thanks, Johann.
June 4, 2019 at 4:55 pm #3953871
Jamal
I suspect that not all the products are fully translated. Maybe the description is not translated on all of them. Can you allow me temporary access to your backend, I would like to check this further.
Jamal
WPML Support
June 5, 2019 at 5:01 pm #3962865
Bigul
I am Bigul from WPML support team. Jamal is on vacation now. So I am taking care of this ticket. Hope it will be okay for you.
Thank you for the login information. I can reproduce the issue on your site(in default language).
But I have doubt, Product Short description is missing for the following products(in default language). Does it use Product Short Description or extracting it from the Product description?
Also, translations needs an update. Please check the attached images and let me know your feedback.
Bigul
The topic ‘[Closed] Translation of products not showing up properly in wishlist.’ is closed to new replies.
