Last updated by Marcos Vinicios Barreto 1 year, 7 months ago.
Assigned support staff: Marcos Vinicios Barreto.
September 25, 2019 at 4:03 pm #4640987
ioannisS-7
I am trying to translate taxonomy "Neighborhoods" from the WPML options -> translate taxonomy but there are two problems :
1) there are not all the taxonomies "Neighborhoods" showing
2) i have translated some of them but still show them as not translated.
September 26, 2019 at 1:51 pm #4647369
Timezone: America/Bahia (GMT-03:00)
Thank you for contacting WPML Support. I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
September 27, 2019 at 3:30 pm #4655601
Thank you for for the updates. I took a look at your WordPress Dashboard and could confirm the issue, an additional and detailed investigation is needed, for that, please consider:
To best troubleshoot the issue, please make a snapshot of your site using the Duplicator plugin: https://wordpress.org/plugins/duplicator/. This will allow me to try and duplicate the error so that I can run further tests without interrupting your live site.
Once the snapshot is complete, either upload the snapshot ZIP file and the installer.php file to a file sharing service such as Dropbox (and share the link in your reply) or right click the Duplicator links in your wp-admin and paste in your reply.
Please note: It is important to reduce the size of the package so please exclude some paths like /cache or /uploads and also exclude archives and media files.I will also need the username and password of an account that was created BEFORE creating the duplicator package.I will enable the next reply to be private so only you and I have access to it!
Thank you for your collaboration. Have a nice day.
September 30, 2019 at 8:51 am #4663111
ioannisS-7
hello again and we are sorry for the delay,
the site is still underconstruction so feel free to make any tests you want...if you still believe that a copy of the site is neseccery please let me know.
Thanks again!
September 30, 2019 at 5:27 pm #4666847
Thank you for the updates. I would prefer a duplicator package for a detailed investigation at my local server, doing so I am able to test different settings, edit files and so on. Please, if it is possible proceed acording my previous instructions, have a nice day,
October 3, 2019 at 8:13 pm #4691241
Thank you for your continued patience while waiting for a solution. I am jumping here to let you know I am working on your issue, I will proceed now with a reproduction of this issue in a clean sandbox install so I can determine if it is something particular for your database only or there's some kind of compatibility issue here. I will update you here as soon as I am done with these additional tests. Thank you for your understanding and patience, have a nice day.
October 7, 2019 at 3:26 pm #4708881
ioannisS-7
Hello again ,
We found the solution of our problem,it was the limit of how many Neighborhood to show.
I have another issue with the translation taxonomy...i believe that is not a bug but if you can help me i would appreciate it. When we try to translate the taxonomy "Neighborhood" , we have only the choice of translation....BUT all those "Neighborhood" are related with a taxonomy "City".....So if there is anyway to translate the taxonomy "Neighborhood" and we have the choice to assign it to the City taxonomy let us know.
October 8, 2019 at 2:47 pm #4716437
Thank you for the updates. The taxonomy relationship field is added by your theme functionality, so it is something not default to WordPress and this is why you don't see it when using the WPMP taxonomy translation feature, I recommend you to give a closer look at the translation preferences for any custom taxonomy from your 'Custom Term Meta Translation' from your WordPress Dashboard > WPML > Settings, you can set any city term to be copied across languages for example.
Another option is to manually assign a city using the default category editing screen instead of the WPML taxonomy translation feature.
See: https://wpml.org/documentation/getting-started-guide/translating-post-categories-and-custom-taxonomies/#translating-taxonomy-terms-using-the-taxonomy-edit-screens
Hope it helps, have a nice day.
October 9, 2019 at 2:28 pm #4723755
ioannisS-7
Hi again!
I tried your solutions but nothing seems to work.
We must find a solution to this otherwise i must translate 1500+ items and then assign each one to a city which is the taxonomy field. And imagine doing this x4 languages that my site has.
I must somehow make it, through the wpml translation to also retrieve the translation of the "parent city" taxonomy..
Please let me know if there is a solution to this.
Thank you very much for your help.
Thanks in advance!
October 11, 2019 at 6:47 pm #4740891
Thank you for the updates. I forwarded your ticket to our second level support, so they can take a detailed look if there's a more convenient way of getting the custom taxonomy settings preserved across translations without having to manually update one by one. I will update you here as soon as I have some detailed reply from them. Thank you for your continued patience and understanding, have a nice day.
October 17, 2019 at 2:29 pm #4774857
Thank you for your patience while waited for a detailed reply. I had some more details from our second level support, and indeed here is a case to be made programatically as WPML don't offer such functionality, I recommend you to get in touch with one of our WPML contractors at https://wpml.org/contractors/ to achieve your desire results. Sorry for not being so helpful here, have a nice day.
