Problem: I need to translate the string 'Please share this' text coming from the options of 'Ocean Social Sharing' from OceanWP. Solution: The string "Please share this" is set in the theme's options and so it is an admin text.
- Go to Appearance -> Customize - Go to "Social sharing" - Do a small edit of the "Sharing Heading" string (eg. "Please Share This!") - Publish it - Go to WPML -> String Translation - Select the domain "admin_texts_theme_mods_oceanwp" - You should find the new string registered and ready for translation - Translate the new string.
If a child theme is in use, you need to register and translate the string by following the steps in the attached article. You can find the string in + theme_mods_oceanwp-child-theme -> oss_social_share_heading Relevant Documentation: https://wpml.org/documentation/getting-started-guide/translating-theme-options/
Last updated by jonB-18 2 years ago.
Assigned support staff: Vincenzo.
May 11, 2018 at 2:40 pm #2090173
jonB-18
I'm struggling to translate the 'Please share this' element of 'OceanWP Social Sharing'. I've found a string and translated it but it's not showing. I've contacted the plugin developer and he's suggested I check with you.
Also, is there a way to translate some of the other key dynamic elements like month name?
May 12, 2018 at 2:05 pm #2100202
Vincenzo
Hello, thank you for contacting WPML Support!
I need more information to be able to help.
1. Can you please paste your WPML Debug information in the Debug information field?
- http://wpml.org/faq/provide-debug-information-faster-support/
2. What is the source of the string that you are trying to translate?
3. In the meantime, can you please verify if there is a cache plugin that needs to be cleared?
4. Check if the "Don't use String Translation to translate themes and plugins" is enabled in WPML -> Theme and plugins localization.
If that option is enabled, please change it to one of the other two: (Translate themes and plugins using WPML's String Translation.....)
5. About the month name, it depends on the source of the string. If the string is coming from a javascript, you may try this solution as an example:
https://wpml.org/forums/topic/translating-datepicker-calendar/
Thank you
May 14, 2018 at 9:05 am #2113557
jonB-18
Thanks, I've added the debug info.
The source of the 'Please share this' text (I think) is a plugin called 'Ocean Social Sharing' from OceanWP.
There's no caching plugin in place.
The 'don't use string translations...' option is not checked (the first one is).
I've rescanned the plugins and added the translation (see the screenshot) but it's not showing.
I'll read the other thread on the month names – thanks.
May 14, 2018 at 11:21 am #2117543
Vincenzo
if the string is set in the plugin's options you may try to register and translate it using the steps shown in this article:
If that is not the case, can you please share with me a copy of the theme so I can test the plugin in my local install? I'm asking because this plugin requires the OceanWP theme to be installed.
Send me the archive file (you probably want to use Google Drive, DropBox, or similar services)
Your next reply will be private, which means that only you and I will be able to see it and have access to it. You can paste the link to the file there.
Thank you
May 15, 2018 at 11:02 am #2136597
Vincenzo
sorry for the delay.
Can you please try the following steps to translate it?
- Publish it
Please let me know if this solves the issue or if you need further details.
Thank you
May 15, 2018 at 11:19 am #2136942
jonB-18
Sorry, this still isn't working. I'm using a child theme and so I don't have a 'admin_texts_theme_mods_oceanwp' domain. I have the corresponding one for the child theme but, despite rescanning the theme I don't see that string even after making the change.
May 15, 2018 at 4:20 pm #2144281
Vincenzo
as you are using a child theme you can register and translate the string by following the steps in this article:
Thank you
May 16, 2018 at 8:45 am #2152324
jonB-18
Thanks but I'm pretty sure I've done all this but it's still not working. If you look at the attached screen shot I've added the translation but it's just not showing on the front end. Now, this may not be the right place to add the translation but I can't find anywhere else.
May 17, 2018 at 11:33 am #2174737
Vincenzo
the string shown in your latest screenshot is not the correct one.
I tested the steps I provided in my previous answer on my local install and everything worked correctly with the child theme.
I would like to request temporary access (wp-admin and FTP) to your test site to take a better look at the issue.
If you don't see the form below, please don't add your credentials as they will be publicly exposed:
- hidden link
Maybe I'll need to replicate your site locally. For this, I’ll need to temporarily install a plugin called “Duplicator” on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok with you.
Thank you
May 17, 2018 at 5:05 pm #2180443
Vincenzo
thank you for the credentials.
I registered and translated the string by following the steps outlined in my previous post here:
https://wpml.org/forums/topic/translation-string-help/#post-2144281
See also the attached screenshot if you wish to find and modify the string translation.
Can you please verify if the issue is solved?
Thank you
May 18, 2018 at 8:46 am #2188604
jonB-18
Thanks, that's solved. I don't know what I was doing wrong but when I followed those instructions I couldn't get that second string to show up. Thanks for sorting it.
