Last updated by Radu 6 months ago.
Assigned support staff: Radu.
August 9, 2019 at 7:06 am #4367897
atilimsan-grup-plastik-ins.-po
I am trying to: translating all strings from Turkish to English but there is a problem with that. For example in my posts, related pages part not translated. It is same for both language. Also share button, it is not changing when i change post language, it is still in Turkish for English language. You can see my problem as attachment.
I expected to see:
Instead, I got:
August 9, 2019 at 7:30 am #4368225
Radu
Hey,
I looked at the elements that you mentioned. Could you go to Dashboard → WPML → Theme and plugins localization → Localization options section and make sure that the Assume that the original language of all strings is English option is unchecked, please? This usually fixes the issues that you have.
If this doesn't make things go back to normal, please give me access to the dashboard area and I'll have a closer look at this.
The next reply is set to be private so you can safely send me the credentials.
Radu
August 17, 2019 at 8:48 am #4409627
Radu
Hey,
Can you tell me if there's any issue on your website, please? I'm trying to access this link: hidden link but I'm getting this message Error establishing a database connection. Can you check this out or tell me if there's anything else I should do in order to be able to access the dashboard area, please?
Radu
August 17, 2019 at 11:36 am #4409877
Hi Radu,
Please try again, i solved that problem. You can access the dashboard.
August 19, 2019 at 5:27 am #4413581
Radu
Hey,
Now, when I try to access this link hidden link I'm getting redirected to hidden link where I can see just Not available. message. Is there anything else I should do in order to access the dashboard area?
Radu
August 19, 2019 at 5:54 am #4413627
Could you share your ip address ?
August 19, 2019 at 7:24 am #4413969
Radu
Hey,
Please use this IP: 74.50.54.120.
Radu
August 19, 2019 at 8:35 am #4414653
Please try again, , add your ip address to whitelist.
August 21, 2019 at 7:45 am #4428631
Radu
Hey,
I was able to access the dashboard area this time by using this link hidden link but now I need a 2FA Code. Can you temporary deactivate this, please? I don't have access to this kind of code so I won't be able to access the dashboard area.
Radu
The topic ‘[Closed] Turkish to English Some Strings Problem’ is closed to new replies.
