Last updated by Riffaz 1 year ago.
April 8, 2019 at 11:14 am #3557037
itzikE
Hello WPML,
Our website is access by multiple domain name, when each domain is set with different language by WPML.
We want to add a second domain name which use an already existing language code (fr-ca) in our site.
How can we achieve this?
Tnx Yaniv
April 8, 2019 at 12:38 pm #3557673
Riffaz
This is the first time we ever received such request.
Currently there is no any option to do this.
You may try adding a custom language with the same language code that you are using already (hidden link) but this is not tested yet.
You can check and see.
I asked this in our 2nd tier support as well.
If they give me any workaround I'll update you again.
Riffaz.
April 8, 2019 at 12:40 pm #3557687
Riffaz
Update:
How did you setup this now and how you want it to be.
In WPML you can have only one domain name per language.
So it's bit confusing here.
April 8, 2019 at 1:26 pm #3558125
itzikE
Hi Riffaz,
Thank you for your reply.
We set it temporary with custom language code but it causing us a lot of issues with SEO,
Our site is available in all kind of languages under different domains, and we need to create a new domain with modified content which should also use fr-ca language code.
Tnx Yaniv
April 9, 2019 at 4:53 am #3563105
Riffaz
I understand your situation but what you are asking is simply is not possible yet.
It's a brand new request.
As I informed you already our second tier is checking this.
I'll update you again once I get a reply from them.
April 10, 2019 at 6:45 am #3572877
itzikE
Hi Riffaz,
Please update us if there is any solution/workaround to this.
Tnx Yaniv
April 10, 2019 at 3:05 pm #3577633
Riffaz
Second tier is asking this:
How did you setup this now and how you want it to be?
They mean how did you create these sites with different domains.
They need the steps to check the possiblities.
May 23, 2019 at 12:13 pm #3874929
Riffaz
We did not hear back you from a long time.
I am sending this email to ask if you still need any help regarding this.
If not, this will be closed automatically.
