Please make sure to update to WPML 4.3.5 and check our list of Known Issues before reporting
Hi, Amit here, I am the WPML Support Manager, our current ticket queue is high, update your WPML plugins and make sure you meet the minimal requirements for running WPML before reporting an issue please - many tickets are resolved doing that
Please look at our updated list of Known Issues and you can also use our support search to find helpful information and of course review our documentation before opening a ticket.
If you do need to open a ticket please make sure to provide us with all the needed information as described in this page
Related documentation:
Last updated by jean-paulS 8 months, 1 week ago.
April 3, 2019 at 12:07 pm | |
jean-paulS |
Hi, |
April 3, 2019 at 3:03 pm #3527749 | |
Yvette Supporter
Languages: English (English ) Spanish (Español ) Timezone: Europe/Madrid (GMT+01:00) |
Hello I just tested this in my local test system setup with domains-per-language and was unable to reprdouce the problem. I also connected to your site and confirmed that the problem exists as you described. Could you please confirm that this same problem happens if you temporarily change your active theme to Twenty Seventeen and also temporarily deactivate you non-WPML plugins? As a preliminary diagnosis, I can see that there is an error reported when attempting to post the comment in the NL language of the type: So it seems a problem of cross-domain permissions but it is not clear if this is being caused by our plugins, another plugin or by your theme. I will be investigating if there are any reported errors of this type while you do the diagnostic tests as requested. |
April 3, 2019 at 4:49 pm #3528931 | |
jean-paulS |
Hello Yvette, |
April 3, 2019 at 5:09 pm #3529199 | |
Yvette Supporter
Yes. That is what you should do until you find which plugin is causing the issue. |
April 3, 2019 at 6:19 pm #3529681 | |
jean-paulS |
Hello Yvette, once again, |
April 3, 2019 at 6:39 pm #3529833 | |
Yvette Supporter
Congrats! Ok - should we keep this ticket open or close it? I`ll leave it up to you. |
April 3, 2019 at 7:29 pm #3530177 | |
jean-paulS |
Well, if it should be possible to keep using the WPBruiser plugin, I won't say no. So you can open a compatibility ticket. |
April 4, 2019 at 6:38 am #3532349 | |
Yvette Supporter
Ok. I have prepared the following sandbox site wiht pre-loaded/pre-configured WPML plugins. hidden link Once this is done, I can then send it to the comaptibility team. |
April 4, 2019 at 7:16 am #3532777 | |
jean-paulS |
I see that when I disable “Protect Comments Form” in the WPBruiser “WordPress” settings, I can post a comment on the Dutch posts. The protection is about the maximum number of characters for comment field, name, email and website field. This is of course very handy for preventing spam and too long comments, and I would like to keep it enabled if possible. So the problem lies there. |
April 4, 2019 at 7:19 am #3532797 | |
jean-paulS |
Didn't saw your latest reply. Will upload the plugin and the example. |
April 4, 2019 at 7:46 am #3532885 | |
Yvette Supporter
Great - thank you! |
April 4, 2019 at 8:21 am #3533111 | |
jean-paulS |
On the sandbox site, I can't submit a comment, not even on the English posts when WPBruiser is enabled. I have to deactivate it completely to post a comment. Under "Reports" in the WPBruiser "settings", you can see the Blocking reasons and under "View Blocked Content" what I did (in the "content" of the comment) and on which part of the site (Spanish or English). The comments I could write on both parts are with WPBruiser disabled. I suppose you send my previous remarks to the compatibility team as well? |
April 5, 2019 at 10:19 am #3543019 | |
Yvette Supporter
Hello I was able to post a comment in the default language but it needed moderation. In any case, the compatibilty team will do thorough testing - no worries. |
April 8, 2019 at 6:57 pm #3560887 | |
Yvette Supporter
Hello I have been given a "fix" that I´ve tested on the sandbox site and it seems to work. Please go ahead and test there. The fix is the following. with the following line: $clientUrl = esc_attr(esc_url(site_url('/', MchGdbcWpUtils::isSslRequest() ? 'https' : 'http') . '?gdbc-client=' . GoodByeCaptcha::PLUGIN_VERSION . '-')); This is essentially the same line but with the "home_url" being replaced with "site_url". If you are satisfied that it fixes your situation, please go ahead and implement the fix on your own site. You should also notify the plugin author about the fix and be aware that if you upgrade the plugin you may overwrite the fix. The ideal situation is that the plugin author will include the fix in the next plugin release. Kind regards |
April 10, 2019 at 8:07 am #3573299 | |
jean-paulS |
Hello Yvette, |
