The client is experiencing an issue where the process of updating affected posts for changes in translatable fields is stuck on the 'custom_title' custom field after updating WPML and String Translations plugins. The process is halted at 50 entries and does not progress despite retries.
1. Ensure that all WPML plugins are updated to their latest versions.
2. Backup the entire site.
3. Run all troubleshooting options available under WPML > Support > Troubleshooting, except for those that involve resetting.
4. If the issue persists, consider truncating the 'icl_background_tasks' table and re-uploading the initial database before updates.
5. Check server and PHP configurations, as discrepancies in these settings across different environments might contribute to the issue.
6. If none of the above steps resolve the issue, we recommend opening a new support ticket. Additionally, it's advisable to check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins.
If these steps do not resolve your issue, please do not hesitate to contact us for further assistance by opening a new support ticket at WPML support forum.
This topic contains 27 replies, has 1 voice.
Last updated by Kor 5 months, 3 weeks ago.
November 6, 2025 at 5:29 pm #17554939
T4ng
I am trying to update our plugins, specifically WPML from version 4.7.6 to 4.8.4 and String Translations from version 3.3.3 to 3.4.1. The issue can be seen at hidden link.
The process of updating affected posts for changes in translatable fields is stuck on the "custom_title" custom_field. The first batches ran fine, but this one is now stuck at 50 entries for 20 minutes. and retrys are stuck at 7.
Why is the update process stuck on the custom_title field?
How can I resolve the issue of the update process being stuck?
November 6, 2025 at 6:28 pm #17555166
Bobby
WPML Supporter since 04/2015
Were you able to successfully update your WPML plugins to their latest versions?
I can see that there are over 4000 items being translated, sometimes when the size is this large it can take a bit longer for all translations to be fully processed.
Please review and let me know if the progress is still stuck or has moved forward yet.
Also, please verify that you have enough credits available or the pay as you go plan is active as if you run out of credits the process will pause.
November 6, 2025 at 10:10 pm #17555630
T4ng
Hi Bobby,
Our WPML plugins are now up to date. The situation I describe is consecutive to these updates.
The previous processes went fine, I could see the figure increaise for a specific process, until it was done, then the following started, and so on. .
When it came to this one, though, it first had the "play" pictogram, but didn't progress further than 50. I noticed the retry_count was 7 in the database.
Then I ran the fixes sugggested by the bot.
And when I checked again, the retry_count had raised to 10, and the pictogram moved to pause while the count was still 50.
It didn't progress since.
Should I try to run the "optimize translation table" troubleshooting option?
What is the meaning of these pictograms?
November 7, 2025 at 12:47 am #17555824
Thanks for your reply. Please backup the entire site and run all troubleshooting options in WPML > Support> Troubleshooting, except the ones that stated "reset". Let us know how it goes.
November 7, 2025 at 9:18 am #17556387
T4ng
I did run all the optimizations and fix (besides synchronize post taxonomies), and it didn't change anything.
I also trid to run the cron manually, with no more luck.
However, everything seems to run fine on our staging environment.
I don't know what makes it wrong on the local env since the db are were updated on both of these environments 2 days before. So that, besides the paths, they were literally the same dbs.
A difference though, is that the local env runs php 8.4 instead of 8.2 on 8.1 on staging. But I doubt it changes anything?
Since the stuck environment is a dev. environment, for now I'll just bring a new, up to date db in, from the live website, and see how it goes.
By the way, in case I still don't get better results, can you tell me if there's a way to re-start / un-pause a process, as the custom_title one I'm facing right now?
November 7, 2025 at 2:30 pm #17557583
Thanks for your reply. There isn't a stop option for that. I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
November 7, 2025 at 3:14 pm #17557730
T4ng
Update: on this specific environment, the exact same behavior happened with an up to date database.
I tested it agains php 8.2 and 8.1 as well. Same issue.
I also tried to apply the database optimizations.
These ran fast, but the process get stuck anyways.
We won't share access to our staging env. Anyway, it worked fine here.
I can't share access to a local env.
Copying it wouldn't make sense since it's obviously environment related.
Nothing pops from the debug info?
November 7, 2025 at 4:48 pm #17558055
Thanks for your reply. I've checked your debug info and it looks fine for me. Maybe try increasing the "TimeLimit" or "MaxInputVars".
November 10, 2025 at 3:03 pm #17563079
T4ng
Hi Kor,
Thanks for the suggestions, but it didn't solve the issue. Still, we highly suspect that's a webserver or PHP configuration issue.
We'll compare our different environments settings and hopefully, let you know what was missing as soon as we know.
Best Regards
November 10, 2025 at 3:21 pm #17563203
Thanks for your reply. Alright then, let me know how it goes.
November 13, 2025 at 2:08 pm #17575309
T4ng
Hi Kor,
I added some php settings to my local environment, based on the setup of the stating environments, where the updates went fine. Unfortunately, it didn't help: I'm still stuck at the same state.
Since on our staging environment, and on another local development environmentn, the updates went fine, we thought the issue only occured on my local environment , so decided to go live.
Unfortunately... The updates got stuck on the live environment as well. At the exact same step.
Can you please provide us with clear explanations regarding this process:
- What is it supposed to do? "Updating affected posts for changes in translatable fields" is very generic.
- Is it required to complet these updates before working on the website again?
- Are we supposed to clear the WPML caches, or process other further troubleshooting options, before, during or after (if they finally complete) these custom fields data updates?
- What the "attempts", counted in the database, correspond to (meaning what ends an attemps, and creates another)?
- One thing we noticed is that my local environment has this step "paused" (pause pictogram), while the live is stuck at the exact same stem and is in the "active" state, (play pictogram) for over two hours now. We obviously have no action as a user, so what manages this state?
Such explanations would help us better understand what's going on here.
Best Regards,
November 13, 2025 at 6:13 pm #17576534
Thanks for your reply. Since you’re using ACF together with Advanced Custom Fields Multilingual, any changes made to your custom fields will sync automatically once the translation settings are configured as described here https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/#translate-with-acfml .That’s why you’re seeing the updates.
However, it seems the process got stuck, which may indicate a corrupted database table. Without access to your Website, I won’t be able to troubleshoot or escalate this to our 2nd Tier Support.
For now, please review your custom field settings to ensure everything is configured correctly.
November 14, 2025 at 11:10 am #17578627
T4ng
Hi Kor,
Some custom fields were not up to date.
But they weren't either on the environments where everyhing ran smoothly.
I updated them on my local env, cleared WPML cache + WP cache + WP transients, then all of this again. The only change I notice the custom_title update process moving from pause to run.. . then back to pause again.
I somewhat understand that these updates could be related with automatic translation
I also notices this thread is tagged ATE.
So I need to mention we are NOT using the automatic translation, and NOT using the ATE (we use the CTE to be able to work with XLIFF imports).
Please open an access to duplicator, I'll take some time to give a try again for a duplication of this stucked local environment.
Best Regards
November 17, 2025 at 3:04 pm #17584601
Thanks for your reply. Sorry, what do you mean by "open an access to duplicator"? Do you mean you need the duplicator pro plugin activated on your Website?
November 17, 2025 at 4:21 pm #17585230
T4ng
Yes, but if it's not required, I can try without it.
In the meantime, can you please answer the following questions?
1. Are these updates related/consequent to the WPML version we updated to?
2. We have some content in the process of being translated. Do we need to wipe this before these updates run (which would be very constraining)
3. Do we need to run the Database Tables Optimization before there updates run?
4. Do we need to update sync the custom fields before these updates run?
5. Do we need to clear WPML cache before these updates run?
