Last updated by Mihai Apetrei 9 months, 1 week ago.
Assigned support staff: Mihai Apetrei.
August 14, 2019 at 5:57 am #4392535
aliY-5
I am trying to:
i want the urls of my site to work only with /ar/ but it works with it and without
I expected to see:
Instead, I got:
August 14, 2019 at 9:57 am #4393927
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
I think what you need is to go to WPML > Languages and select the "Use directory for default language" checkbox, then Save.
I am also attaching a screenshot as an example.
Kind regards,
Mihai Apetrei
August 14, 2019 at 11:41 am #4394535
aliY-5
this option is activated but i still can visit both links
August 14, 2019 at 11:54 am #4394619
Mihai Apetrei
Thank you for letting me know.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
- Please make a backup of the site files and database before providing us access.
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box.
The private box looks like this: hidden link
In order to be able to help you faster, can you also please paste your WPML Debug information in the Debug information field?
Kind regards,
Mihai Apetrei
August 14, 2019 at 9:27 pm #4397679
Mihai Apetrei
Hi and thank you for the credentials.
I can confirm that they worked and I was able to log in.
When I go to WPML > Languages (hidden link), I see the errors in the screenshot below.
That might be the reason why that doesn't work.
Can you please analyze the errors there try to see which ones of them are applicable to the current situation?
Please let me know what you are able to find.
If you still need help, I will be more than happy to look it out for you, but I will need your written approval to also enable/disable plugins so please create a full backup of the site before that.
Kind regards,
Mihai
August 15, 2019 at 2:14 am #4398273
aliY-5
what code do u need to add it in .htaccess file
August 16, 2019 at 1:15 am #4403881
aliY-5
August 16, 2019 at 9:06 am #4405549
Mihai Apetrei
Hi and sorry for the delayed response.
I did not work yesterday.
Regarding your question, I did not say that there's something that needs to be added to the .htaccess file, I just said that there are a lot of hints there, written in red, and I can't know for sure which one of them is the one that we need to implement, until I don't take a deeper look (but for that I will need your written approval).
However, I wanted to leave you the option to check the errors on your own, if you preferred that.
Please let me know if you are ok with me investigating deeper on this (if you want this, I will also need you to please check the SFTP/FTP credentials once again as they don't work for me to log in - can you also please let me know what port should I use?).
Thank you and I will be waiting for your response.
PS: Just a note that I won't be working on the weekend so I will be able to get back to you at the beginning of next week.
Kind regards,
Mihai
August 16, 2019 at 6:43 pm #4407865
aliY-5
nvm i requested refund
August 19, 2019 at 4:42 pm #4417505
Mihai Apetrei
I understand.
I am very sorry to hear that and I wish that I was able to help you forward with this.
Going forward, can you also please confirm that it is ok for you if I will close this ticket?
Kind regards,
Mihai
The topic ‘[Closed] url working both with /ar/ and without for same topic’ is closed to new replies.
