Our next available supporter will start replying to tickets in about 2.85 hours from now. Thank you for your understanding.
Last updated by Bruno Kos 8 months, 2 weeks ago.
Assigned support staff: Bruno Kos.
September 18, 2019 at 6:39 am #4592717
andreB-25
I'm trying to stringtranslate my custom template with aall the posts and content currently in it and i was told that i need to write like 2 lines of code to do that. In your doc, i only find the _e function solution, but that means i need to review thousends of codelines and add the _e function to each of those. Is there no faster way? I'm running on the latest WordPress and WPML versions at this time.
Thanks for your help
September 18, 2019 at 7:31 am #4593225
Bruno Kos
Can you tell me if you seen my messages I posted within chat?
https://wpml.org/forums/topic/using-string-translater-for-my-custom-theme/#post-4593053
I was asking whether you are trying to translate the theme strings or the content you written in fact, like pages, posts, etc?
Bruno Kos
September 19, 2019 at 10:56 am #4603853
andreB-25
I did manage to add them to the stringtranslator, i missunderstood that i only needed to use the function on hard strings, i thought i had to add it somehow in the query aswell but alright, thanks for that.
My next question is about adding my a custom menuitem for the language switcher, here is what i prepared so far.
<li class="nav-item dropdown py-md-2"
                    role="presentation">
                    <a class="nav-link dropdown-toggle"
                       data-toggle="dropdown"
                       href="#" role="button" aria-haspopup="true"
                       aria-expanded="false">
                        <?php if(ICL_LANGUAGE_CODE=='de'){ echo 'Deutsch';} else {echo 'English';}?>
						<span class="caret"></span>
                    </a>
                    <div class="dropdown-menu"
                         aria-labelledby="dropdownMenu1">
                        <a class="dropdown-item" href="#">English</a>
                        <div class="dropdown-divider"></div>
                        <a class="dropdown-item" href="#">Deutsch</a>
                    </div>
                </li>
I didnt find any solution yet on to how i take the current url, remove the ?lang=de and replace it with ?lang=en and vice versa, can you help me out on this problem?
September 19, 2019 at 1:07 pm #4605059
Bruno Kos
Is there a reason why you haven't tried this yet?
https://wpml.org/documentation/getting-started-guide/language-setup/language-switcher-options/#separate-sections-for-different-kinds-of-language-switchers
You can simply assign language switcher to any menu and style it as you wish.
Or you can code the language switcher, as described here:
https://wpml.org/documentation/getting-started-guide/language-setup/custom-language-switcher/
Bruno Kos
