I want to use string translation to translate plugins+theme but changes are not visible.
This is how you translate the theme with String Translation:
### String Translation: Scan theme and plugins for strings ###
Provided that you have the "WPML String Translation" add-on installed please follow these steps:
1.) Go under "WPML -> Theme and plugins localization" 2.) Make sure that "Translate by WPML." is active 3.) Scroll down to "Strings in the theme" and click on "Scan the theme for strings" 4.) Scroll down to "Strings in the plugins", select the plugin you want to scan and click on "Scan the selected plugins for strings" 5.) Once you followed the above steps go under "WPML -> String Translation". All strings available for translation should display in the table you see there.
Do you see them? If yes, all you need to do is click on "translations" next to each string you want to translate.
Last updated by Robert 4 years, 3 months ago.
Assigned support staff: Thomas.
July 29, 2016 at 2:08 am #980933
Robert
I have Chinese as default language and actually don't need English as secondary language since the website will be Chinese only.
I want to use string translation to translate plugins+theme but changes are not visible. Unless I change the string translation language from Chinese to English which is backwards (see screenshot)
Seems like a bug? or am I doing something wrong?
July 29, 2016 at 8:19 am #981264
Thomas
Hello and thank you for contacting WPML support!
For further information or if you have any questions related to this ticket please do not hesitate to contact us.
July 29, 2016 at 8:43 am #981301
Robert
Re-scanning seems to have fixed the issue. Many thanks!
