You are unable to use the same slug for translated products in different languages after updating to version 4.7, which changes the slug automatically as if it were already taken.
If you're experiencing this issue, we recommend adjusting your WPML settings. Go to WPML > Settings > Translated documents options > Page URL. Here, you have a few options:
1. Set this option to Translate to manually translate the slugs using the WPML Translation Editor.
2. Set the option to Copy if you want to maintain the same slugs across all languages.
After making these changes, remember to update your translations to apply the new settings.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by 1 year, 1 month ago.
