Last updated by Carlos Rojas 6 months, 4 weeks ago.
July 30, 2019 at 9:09 am
chrisV-26
I used WMPL to translate my woocommerce store from Greek (main language) to English.
After I translated my products I noticed that some of them don't have a price, options or an "add to cart" button. I tried the steps described here: https://wpml.org/forums/topic/product-variations-not-showing-even-after-trying-suggested-solutions/ to no avail. Furthermore, I noticed that they list as 'simple products' in the backend when they should be variants (almost all my products are variants).
Example Product
Greek: hidden link
English: hidden link
How can I fix this?
P.S. I have currently changed the main language to English, you can switch from the main menu.
P.S.2. The website is still on beta, no traffic whatsoever.
July 30, 2019 at 4:48 pm #4309777
Carlos Rojas
I would like to ask you to follow this steps:
- Back up your site first before making any change, this is for security reasons.
- Update all outdated plugins and themes, specially WPML plugins, to their latest version. Outdated functionalities can cause conflicts in the code.
- Flush any cache memory that might exists.
- Click on the 'Product categories' link that appears in the admin message and sync all product categories.
- Go to WPML -> Support -> Troubleshooting link -> Apply the steps pointed out in the attached image.
- Go to Woocommerce -> Woocommerce Multilingual -> Settings tab -> Troubleshooting link (bottom right) -> Select all options and click on the 'Apply' button.
Could you tell me if the issue disappeared after the steps above?
Kind regards,
Carlos
August 1, 2019 at 8:54 am #4319989
chrisV-26
We followed all the steps you provided us.
However the issue persists.
What should we do next?
August 1, 2019 at 11:29 am #4321117
Carlos Rojas
Could you tell me if the issue persists with newly created products too or only previously created products?
Carlos
August 1, 2019 at 12:01 pm #4321349
chrisV-26
It does it on new products also. My process is:
- Create a variable product in Greek
- While editing the Greek product change language to English
- Change title/description and save
The English version is a "simple product" instead of "variable". The attributes show up fine.
August 1, 2019 at 6:16 pm #4324623
Carlos Rojas
I'm not quite sure I understand this part: "While editing the Greek product change language to English"
How do you exactly switch the language to English? Please attach a screenshot so I can have better understanding.
Carlos
August 2, 2019 at 9:38 am #4328575
chrisV-26
I attached the image.
August 2, 2019 at 4:51 pm #4331649
Carlos Rojas
Thank you for attaching the image to your previous message.
According to the image the products are being translated in the wrong way. To translate a product correctly you need to follow the steps described in this link: https://wpml.org/documentation/related-projects/woocommerce-multilingual/#products
Please let me know if you need further help.
Carlos
