| - | 8:00 – 12:00 | 8:00 – 12:00 | 8:00 – 12:00 | 8:00 – 12:00 | 8:00 – 12:00 | - |
| - | 12:00 – 16:00 | 12:00 – 16:00 | 12:00 – 16:00 | 12:00 – 16:00 | 12:00 – 16:00 | - |
Last updated by Dražen 15 hours, 32 minutes ago.
Assisted by: Dražen.
| Author | Posts |
| April 30, 2026 at 9:59 am | |
annikaN-2 |
We have change the main language and have big problems whit some parts. We had Swedish as the default language and changed to English because Directorist didn't work in some parts for our clients. |
| April 30, 2026 at 10:40 am #18005298 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, thanks for the patience, I have found what was missing. In directory builder you are using custom template page, but that was not set for EN side. From directory builder I edited Nightlife and under custom template set correct translate page (that you are using as template - Natliv template). - hidden link It works fine now, please check. Regards, |
| April 30, 2026 at 10:50 am #18005442 | |
annikaN-2 |
I saw that but now the Swedish doesn't work so how I solve that? Also there is a problem with the woocommerce products, not the Free once but the other that we sell, can you also please have a look at that Thanks a lot, |
| April 30, 2026 at 10:55 am #18005447 | |
annikaN-2 |
I just send you a reply but I can't see it. I see that the Hassapiko bar now is in English but the Swedish doesn't show now and when I go to update the translation of the Swedish it doesn't open your Translator, instead it open the ordinary wp editor. Also we have problem with the woocommerce products, not the free once but the other that we sell so can you please have a look at that also Thanks a lot, |
| April 30, 2026 at 11:22 am #18005568 | |
Dražen Supporter
Hello, please let’s focus on the main issue, as we limit one issue per ticket to keep things clear. If needed, we can always open a new ticket later and continue from there. Regarding the template, I’ve set it again and it’s working correctly now. You can see it here: From what I can see, the issue is likely caused by mixing default languages between pages and templates, along with using manual translation methods. Also, you currently have the page set to use the WordPress editor instead of the WPML Translation Editor (see attached image). I would suggest deleting the template (or ensuring its default language is also English), then recreating/saving it and translating again. Additionally, switch to using the WPML Translation Editor for more consistent results. Let me know how it goes. Kind regards, |
| April 30, 2026 at 11:40 am #18005658 | |
annikaN-2 |
Thank you for your fast answer and what template are you talking about? |
| April 30, 2026 at 12:00 pm #18005712 | |
annikaN-2 |
Also wonder if I need to have the wordpress editor or it's just for you to test? |
| May 1, 2026 at 9:01 am #18007447 | |
annikaN-2 |
Any news about the above? |
| May 1, 2026 at 9:53 am #18007465 | |
annikaN-2 |
Just to alert you on other issues that occured; |
| May 4, 2026 at 6:37 am #18009925 | |
Dražen Supporter
Hello, I’m referring to the template used for that page/listings: Nattliv template If you didn’t build the website, it would be best to check with the original developers, as there are many interconnected elements and some complexity, which could explain why this was missed. You don’t have to use the WordPress editor—you can use the WPML editor. However, please note that any manual changes made in the WordPress editor may be overwritten, and you would need to translate that content again. Since mixing methods is not recomanded. I would not say this is global issue, I would say that mixing default languages and correct settings missing is causing the issue, as it was with template settings missing. As we keep one issue per ticket to maintain clarity, please open a new chat for any additional issues and we’ll be happy to help further. Regards, |
| May 4, 2026 at 8:40 am #18010170 | |
annikaN-2 |
Hi again, 1. Is the problem caused by the change of main language 2. Is it possible to change the main language with this complex structure? For us it's important to change because of the payment gateway etc. But I thought maybe instead delete all directories, templates, listings etc and use import export instead. If we do that shall we start to import all in English and then change to Swedish up in the top menu and import everything in Swedish and so on? Thank you, |
| May 4, 2026 at 9:53 am #18010440 | |
Dražen Supporter
Hi Annika, thank you for your message, I understand the confusion here. The main issue is that changing the default language does not update the language of already existing content. All content, templates, and listings created before the change remain tied to the original default language, while any new content is created in the new default language. This leads to a mixed setup, which is likely what you are experiencing now. Technically it is possible to continue working with this setup, but with a complex structure (templates, listings, etc.), it requires careful manual checking. You would need to review all templates, assignments, and settings to ensure they match the correct language, since some are still tied to the old default language and others to the new one. Regarding your proposed approach, the safest recommended way would be: - create a fresh staging site This avoids mixing languages and ensures a clean and predictable setup. Regards, |
| May 4, 2026 at 10:04 am #18010450 | |
annikaN-2 |
Thank you very much for your explanation and this was the way I was thought I will do. But one last question. After that you point "once everything works correctly, enable WPML and translate into the secondary language (e.g. Swedish)" import Directories and listing in Swedish? This would be fantastic but maybe not possible, we have loads of listings and it will take us a lot of time and do everything manual. Thanks, |
| May 4, 2026 at 10:19 am #18010515 | |
Dražen Supporter
Hello Annika, I’m not entirely sure which Import/Export option you are referring to. If you mean the Directory import/export tool, I’m not certain how it works or if it would be correctly in this case, as WPML requires its own data structure to properly connect listings and translations. We do have our own import/export procedure that you can use on next link or WPML All Import way: However, even with that approach, the content (posts, listings, etc.) would still retain the original default language, which is why I didn’t recommend it earlier and instead suggested starting with a clean setup. Regards, |
| May 4, 2026 at 10:44 am #18010560 | |
annikaN-2 |
Thank you and I understand. In Directorist you use .csv files but I will have a look at your tools. |
