July 15, 2019 at 12:59 pm #4211263
mohammadA-31
I am trying to:
view some text in both language but not view correctly, like "احصل عليه الان" it should be "Get It Now" in english products.
I expected to see:
Get It Now text in button
Instead, I got:
we was add multi translation text using "String translation" but not view in web
July 15, 2019 at 3:52 pm #4213115
Do I understand right, that the string was translated on String Translation?
Can you verify if that the string is assigned to the correct language? On String Translation each strings has added a flag in its row, which indicates the default language of the string. In case the wron default languge is assgined you can mark the checkbox for the affected string and then change the efault language for the selected string at the bottom of the window.
https://wpml.org/documentation/getting-started-guide/string-translation/
I hope this will solve the issue.
Kind regards
July 16, 2019 at 7:27 am #4217081
mohammadA-31
we add translation but still not appears
July 16, 2019 at 2:26 pm #4221025
mohammadA-31
please can you help me to solve the issue
July 16, 2019 at 3:27 pm #4221741
I can see there are two affected strings. One is based on WooCommerce and anopther one is based on the Woodmart Theme.
Could you please try to run the site in minimal setup to see if the issue persists?
Please disable any additional plugin than WooCommerce and WPML and its add-ons. If the issue disappears please start reactivating any plugins, or activate them in small groups. This way please verify at which points the issue appears again to indicate the plugin that is causing the issue.
Also please change to a default theme like TwentySeventeen to see if the issue might be theme related.
Further, you could enable the wp-debug feature to see if there are any current PHP errors given.
Add the following to your wp-config.php file:
define('WP_DEBUG', true);
The wp-config.php is located in your WordPress root directory. It’s the same file where the database configuration settings are. You will have to access it by FTP or SFTP in order to edit it.
If you open wp-config.php and that define statement is not there, you can add it right before this line:
Now please go to the page that should include the translations. In case of existing errors you will be able to find a complete report inside of your wp-content folder. Look for a debug.log file and provide me the results.
More information about how to activate this feature you can find here:
Once we indicate which plugin is causing the issue we can take further steps. Let me know about the outcome.
Kind regards
July 17, 2019 at 2:15 pm #4231183
mohammadA-31
Hi
we do all your advice
and the error give me is :
2019-07-17T13:49:06+00:00 CRITICAL method_exists(): The script tried to execute a method or access a property of an incomplete object. Please ensure that the class definition "WPML_LS_Template" of the object you are trying to operate on was loaded _before_ unserialize() gets called or provide an autoloader to load the class definition in /opt/lampp/htdocs/wp-content/plugins/sitepress-multilingual-cms/classes/language-switcher/class-wpml-ls-templates.php in line 304
July 17, 2019 at 9:16 pm #4233557
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated.
Maybe I'll need to replicate your site locally. For this, I’ll need to temporarily install a plugin called “Duplicator” on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok with you.
IMPORTANT
Kind regards
July 18, 2019 at 4:32 pm #4241073
Thank you for your message.
I haven been troubleshooting your site and foudn out that the issue disappears when the plugin WC Custom Add to Cart labels is disabled. the issue further persist if only WooCommerce, WPML and its add ons and WC Custom Add to Cart labels are activated.
It seems that we are handling with a compatiblity issue between The Woodmart Theme, WPML and WC Custom Add to Cart labels. Does the issue disapear if you switch to the default Woodmart theme or even switch to default WordPress theme like Twenty Nineteen?
I have installed the plugin WC Custom Add to Cart labels on the following test site for further investigation. With the current setup the button is translated as expected, which for the issue must be linked to your theme:
One Click Login: hidden link
I would kindly like to ask you to install the Woodmart and add your child theme for further investigation.
Leave me a short message once the themes are installed.
Kind regards
July 21, 2019 at 7:03 am #4251509
mohammadA-31
Hi
kindly, the themes are installed.
Regards
July 23, 2019 at 8:33 am #4263953
mohammadA-31
any update please...
July 24, 2019 at 1:20 pm #4275073
mohammadA-31
please, any update ??
July 30, 2019 at 3:23 pm #4309063
Mihai Apetrei
Hi and thank you very much for your patience!
I am very sorry for having you waiting.
My colleague is off for the moment and the ticket got assigned to me today (we also don't work on the weekends) so I will be more than happy to assist you going forward.
I read the ticket and I also checked the sandbox where you installed the theme and activated it.
From what I can see here (hidden link), the button translation still works even after you installed and activated the theme.
Also, I can see on your site here (hidden link) and here (hidden link) that the button translation works just fine.
Can you please let me know if the issue is still happening?
I will also attach some screenshots so that you can see what I see.
Please let me know.
Kind regards,
Mihai Apetrei
July 31, 2019 at 10:16 am #4313633
mohammadA-31
when we remove arabic button content, and add translation of english they appears correctly,
but still currency symbol error ... it is appear in english products (arabic symbol) and hide in arabic products
July 31, 2019 at 3:31 pm #4316103
Mihai Apetrei
Hi.
I am very happy to hear that we are making progress.
I can indeed see that the currency is exactly the opposite at the moment.
From what I can see, you did not enable the WooCommerce Multilingual Multi-currency functionality yet.
Can you please take a look over the documentation below and see if that solves the issue for this:
https://wpml.org/documentation/related-projects/woocommerce-multilingual/multi-currency-support-woocommerce/
You should be able to find that tab here:
Please let me know if that solved the issue or if you still need help.
Kind regards,
Mihai Apetrei
