Last updated by Mihai Apetrei 8 months, 3 weeks ago.
Assigned support staff: Mihai Apetrei.
May 31, 2019 at 6:42 am #3928025
parvizs
I recently transfer my website to a new server. When I am adding menu it doesn't work and when saving a review it always got Gateway Timeout.
May 31, 2019 at 1:32 pm #3930901
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
1. Can you please let me know how did you migrate the site? We usually recommend the Duplicator plugin for doing that.
Documentation can be found here: hidden link
Here is a small tutorial on how to use Duplicator:
2. If you think the migration was done correctly, can you please make sure that the hosting plan your site is on is following the minimum WPML requirements here:
3. Please make sure that you are using the latest updated version for the plugins and the theme.
4. If that is ok, can you please try this:
- disable all plugins except WPML and its add-ons
- check if the issue is happening again
- if it's not, reactivate your plugins one by one, checking every time if the issue shows up again so that you can understand which plugin is causing that issue
If the issue happens even with the non-WPML plugins disabled:
- leave all the non-WPML plugins deactivated
- switch to a default theme like TwentySeventeen
- try to recreate the issue now
Please let me know how that goes and if you are able to find anything new.
Just a note that I won't be working on the weekend so I will be able to get back to you at the beginning of next week.
Kind regards,
Mihai Apetrei
