August 3, 2018 at 11:57 am #2609422
kateA-3
I am using WPML plugins on my website. Everything was working fine but recently I have upgraded my server (go-daddy) and it affected speed of website. Now, website is quite slow when we browse front-end or even at back-end I was not able to add product and variations due to slow speed. I have contacted with my server support for this concern and they have cleared no issue from their server side. When i deactivated all plugins of WPML then website speed improves. I think there is confliction in wpml plugins that affecting my website.
Please have a look on my website and help me to fixed this issue as soon as possible.
Here are the admin details:
Website Link: hidden link
Username: ***
Password: ***
August 3, 2018 at 9:43 pm #2611767
Carlos Rojas
I applied some actions to increase the speed of the site. However I would like to ask you to update all outdated plugins and themes to their latest version and run the Woocoommerce update.
Outdated functionalities can cause conflicts in the code.
Could you tell me if the issue persists after the steps above?
Kind regards,
Carlos
August 4, 2018 at 8:06 am #2612457
kateA-3
Thanks for your support.
I have tried by updating all the plugins but still issue has not been fixed. Website is quite slow.
Also,when I create any variable product then it takes too much time to create variations. So, might be any wpml plugin that is conflicting? Please have a look and solve this issue as soon as possible. Because due to slow speed I am not able to add products to website.
August 6, 2018 at 3:11 pm #2616373
Carlos Rojas
I suspect that this could be caused by a compatibility issue, I would like to ask you to follow this steps in order to isolate the cause of the issue:
- Back up your site first before making any change, this is for security reasons.
- Deactivate all the plugins that are not related to WPML.
- Switch for a moment to a WordPress default theme like Twenty Seventeen.
- If the issue is gone, activate one by one to see with which one there is an interaction issue.
Could you tell me the result of this steps?
Carlos
August 18, 2018 at 8:31 am #2655637
kateA-3
I have tried by disabling WPML plugins then website speed increase a little bit. I have also checked error.log file for website, most of errors are generating from WPML plugins.
For instance 'wp_pc491hxk4v_icl_string_translations' table generating error 'WordPress database error Lost connection to MySQL server during query' due to recurring queries. Can you please look through such errors because it preventing website to load. And website speed is major concern, I am not accessible to back-end due to speed.
If there is any compatibility issue then you can also share. Please do testing on staging website: hidden link.
August 20, 2018 at 2:03 pm #2659548
Carlos Rojas
Our Debugging Procedures
Carlos
