Problem: Soe gravity forms fields are randomly translated
Solution: Please make sure you update Gravity Forms Multilingual, WPML and Gravity forms to its latest release where this issue has been already fixed.
This topic contains 34 replies, has 3 voices.
Last updated by bothienB 2 years ago.
November 22, 2019 at 3:22 pm #4999611
bothienB
I am trying to:
Display a form where there are several occurrences of a field with the same label.
I expected to see:
Each iteration of the field(s) with the correct label and values (for select)
Instead, I got:
One or more labels / selects that are inconsistently populated in English.
What I've tried : change the labels (if you change the lang parameter to 'fr' you will see that repeated fields labels have indexes (like 'Civilité0,Nom0, Prénom0,email0)) resulting in various & mysterious combinations of labels being translated while selecte are not, or both ...
Where I am : deep in the red. For weeks now, since the latest "major upgrade"; I believe this was not the case before.
What I need :
- either identify the problem (hint : looks like the replacement is not done against blog+form_id+field_id but somehow on labels/values ?) and solve it in a very short time (i.e "yesterday")
- OR being able to rollback to previous WMPL version that isn't causing the same disaster WITOUT losing all the translations made.
I really need assistance here, that's a major concern and we were supposed to go live (again) last week.
P.S : in native language(fr) we have no problem.
November 22, 2019 at 4:44 pm #5000961
Lauren
Please see my previous private reply and let me know once the migration has been completed. Thanks!
November 22, 2019 at 4:48 pm #5001001
bothienB
Lauren, we are multisite; will it fit ?
November 22, 2019 at 4:52 pm #5001011
Lauren
Yes, it should work just fine. I set up the staging for multisite.
November 22, 2019 at 4:59 pm #5001031
bothienB
Added some details for what blog to test at the bottom of our private initial conversation
6:43 local time (Paris) : still running, copying tables ... 366/849
November 22, 2019 at 5:04 pm #5001071
Lauren
Perfect thanks. Just let me know once the migration is completed - you should receive an email notification.
November 22, 2019 at 6:04 pm #5001345
bothienB
Still running ... last step.
Migrating Site (Copying Database Table - ******o3_icl_string_translations 577 / 849)
November 22, 2019 at 6:25 pm #5001403
bothienB
Lauren : "migrated" but seems to have some DNS/URL issues with sub-sites ...
Maybe it'll be easier if I set you an Admin account on our site ...
November 22, 2019 at 7:07 pm #5001647
bothienB
Please check first message with login infos
November 23, 2019 at 12:53 am #5002341
Lauren
Thanks for the additional info. Unfortunatley, I was not able to login as a Super Admin. Can you please double check those credentials?I was able to add a function to the theme to add a user but that only gives me access to the one blog site and I can't see any of the WPML settings.
Thanks for your assistance.
November 23, 2019 at 7:20 am #5002789
bothienB
Hi Lauren,
This was 1AM in my TZ and unfortunately I stooped monitoring @ midnight ...
it's 8AM Saturday now and I can see that we have URLs problems; none of the sub-sites are accessible.
What I will probably do is duplicate the site in our MU environment and create credentials for you so that you can have a look on Monday. Will keep investigating on my side but one of the things I noticed is that all the icl_xxs tables seems to be pretty heavy ...
We use NS Cloner plugin to generate sub-blogs; is there something here that could explain our problems ?
BR
Antoine.
November 23, 2019 at 9:51 am #5003247
bothienB
Lauren; so I've been digging into the icl_strings and icl_string_translations.
Will try to add my Excel Worksheet in private message but what appears is :
all translation strings are set accordingly to WMPL recommendations :
1. Fields used for logic statement have a value/label attributes pair and the value isn't translated (shouldn't be a problem anyway, as in my case, translation of these values would only be a single digit : 1 or 0 - but I digress)
2. Regarding conditional logis possible issue : well that's not that; I've removed all conditional rules and the result is unchanged.
3. All (Select->Options) labels are properly set as I find all required translations when joining icl_strings.id to icl_string_translations.string_id
4. I tried various configurations of the select fields (setting values to target/original language or unset them) without luck.
So ... where am I now ?
- I believe there's a rendering issue here, not a string settings issue.
- This rendering issue (apparently) only impact select option labels (the select label is properly translated ... now. Pls don't ask me why)
- So I will dig into the Gravity forms multilingual plugin to - try to - find "something weird" ... great weekend in sight 😉
... and of course, will keep you posted.
BR
Antoine.
November 23, 2019 at 11:10 am #5003687
bothienB
There's definitely something wrong in the rendering.
As I'm the kind of person unsatisfied with "don't ask me why" statements, I went back to my form and then reminded that in its original settings, I had several identical labels for several fields resulting in fields label not being translated.
So I changed the names of identical fields (for instance we have a field labelled 'name' for an attendee, 1 for his companion and 1 for his guest -> name0, name1, name2) and noticed they were - finally - translated.
Reverting this to a "normal" situation - where I can freely choose a label for a field - and setting them all back to "name" resulted in expected behavior : none is translated.
Could it be that trivial ? The plugin relying on field/option label instead of field id / option position to get translations ????
November 23, 2019 at 11:34 am #5003837
bothienB
Update : in fact, only the last field *label* is translated (options aren't), while only the first field *options label* are translated (field label isn't). There's definitely a flaw in a loop somewhere ...
November 23, 2019 at 1:25 pm #5004235
bothienB
SO I tried to sniff inside the code and I must say it's probably way above my knowledge to debug this in a proper manner. Thus, as I'm a bit stubborn, I edited the inc/gravity-forms-multilingual.class.php (starting line 685) as below "just in case" I could find "something" :
		// Filter form fields (array of GF_Field objects)
		foreach ( $form['fields'] as $id => &$field ) {
            echo($id); // edited : should give me an idea of the "index" used later
			$snh->field = $field;
			// Filter common properties
			foreach ( $keys as $field_key ) {
				$snh->field_key = $field_key;
				if ( ! empty( $field->{$field_key} ) && $field->type != 'page' ) {
				    echo(' => ' .$field->{$field_key} . ' => ' .icl_t( $st_context, $snh->get_field_common(), $field->{$field_key} ) .'<br>'); // edited to display original string => translated string
				    $field->{$field_key} = icl_t( $st_context, $snh->get_field_common(), $field->{$field_key} );
And - eventually - I did.
If you look at the attachment, you will find that the first iteration of the field "Civilité" (aka "gender" -> same case that what I called "name" earlier in my problem description : multiple occurrences of a field with the same label ) seems to have a "double" ID i.e 13 and 14 resulting in a "merged" 1314 ID that is not in the general logic (+=1) of the (ordered ?) list ...
I'm pretty sure that when returning the $form there will be some hiccups @ rendering ...
Good news is this should not be a heavy fix for your dev team, sadly it also means I'll have to wait until Monday, at best ...
Notes :
- This field has a admin_label ("Guest_Civ") as all other duplicated fields.
- It is the first one to "break translation", I've not met other "double ID" case after.
- Regarding the field labels; all the fields (not only selects, also basic text inputs) with a duplicated label are correctly translated in their last occurrence, otherwise, not translated. Select Options labels are only translated in the first occurrence.
