Problem: Soe gravity forms fields are randomly translated
Solution: Please make sure you update Gravity Forms Multilingual, WPML and Gravity forms to its latest release where this issue has been already fixed.
This topic contains 34 replies, has 3 voices.
Last updated by bothienB 12 months ago.
November 28, 2019 at 10:24 am #5034807
Alejandro
You can change or add a new merge tag or just change a word in the fields that are not currently working (like the confirmation body text). then save it, then try updating the translation through the normal procedure (WPML > Translation Management > translate again the gravity form and update the translation).
That should do it.
Let me know how it goes.
November 29, 2019 at 4:15 pm #5044823
bothienB
Alejandro, Lauren,
so far so good, it seems to do the trick; well done.
I will have to do extensive testing since I must ensure that there's no side-effect elsewhere in the site as I'm hooking several plugins features, etc.
So maybe this ticket may stand open for a while so that we'll keep all together if problems but please, can you perform the cloudways site deletion right away ? Our customers are pretty touchy about this, and even if we've cleaned most before copy, some dust may remain ...
Thanks in advance !
November 29, 2019 at 4:18 pm #5044833
Alejandro
With this status i set, the ticket will remain open for 14 days after your last answer and you'll get notified a few days before it's closed in case you want to "renew" those 14 days, otherwise you can always resolve it if you feel it's all done!
December 4, 2019 at 7:09 pm #5072011
bothienB
Hey Lauren, Alejandro,
the described issue is now tested and appears to be solved.
December 4, 2019 at 7:10 pm #5072013
bothienB
