Problem: I want to translate a word on the checkout page of WooCommerce, because it seems it is not yet translated. When going to the string-translator, I find the word. But it shows up with the wrong language. Then I change the language and translate the word. When reloading the page, still the word shows up without translation. Solution: Just uncheck the Assume that the original language of all strings is English option from the Dashboard → WPML → Theme and plugins localization area and everything will go back to normal.
Last updated by michaelS-139 10 months, 1 week ago.
Assigned support staff: Radu.
July 16, 2019 at 9:55 am #4218533
michaelS-139
I am trying to:
I want to translate a word on an checkout page of woocommerce, because it seems it is not yet translatet. When going to the string-translator, i find the word. But it shows up with the wrong language-flag (this appears at some words or sentences). Then I change the language and translate the word. When reloading the page (also i clear the cache), still the word shows up without translation (see attached screenshots)
first you need to add a product to the shopping cart from the following page:
then got to:
I expected to see:
the translated english word
Instead, I got:
still the german word
July 16, 2019 at 10:31 am #4219135
Radu
Hey Michael,
The string should work fine if you made the translation in WPML → String Translation. Is there any chance that you could give me access to the dashboard area so I can have a closer look at this? The next reply is set to be private so you can safely send me the credentials.
Radu
July 19, 2019 at 7:42 am #4244631
Radu
Hey Michael,
Can you check again the checkout page in both languages and tell me if things are looking fine now, please? I made a small change and the translation should work well.
Radu
July 19, 2019 at 7:52 am #4244723
michaelS-139
Hi Radu,
thanks a lot. It works now. What did you change - just to know if it happens again in the future.
Kind regards and thanks for your help,
Michael
July 21, 2019 at 7:52 am #4251545
Radu
Hey Michael,
I'm glad to hear that everything is back to normal now 🙂
All I did was to uncheck the Assume that the original language of all strings is English option from the Dashboard → WPML → Theme and plugins localization area. I'm sure that this issue won't be back.
Radu
July 24, 2019 at 2:40 pm #4275723
michaelS-139
Hi Radu,
i still have a translation which don't show up correctly.
see attached screenshot:
Can you may check this.
Thanks a lot,
Michael
New threads created by Radu and linked to this one are listed below:
https://wpml.org/forums/topic/text-in-checkout-not-translating/
