This topic contains 25 replies, has 3 voices.
Last updated by Bigul 4 years, 3 months ago.
August 13, 2017 at 2:33 am #1340845
mathieulaflamme
I do not see s_composer_salient folder. Pls see my screenshot
August 13, 2017 at 7:34 pm #1341020
mathieulaflamme
Wow man, I gotta hand it to you, IT WORKED!!!! Amazing! What happened? This is one of the most popular themes in the world! They claim to be fully compatible with your service for several years now. Was this a problem that was unique to me or is it rather common? Thanks agian, please let me know. Cheers
August 14, 2017 at 8:30 am #1341303
Bigul
Thank you for the updates. Glad to know it is working fine for you now.
We have compatibility issues with Salient theme. But most of them we can solve it by adding correct configuration in *wpml-config.xml* file.
It will be great if you can request the theme author to apply for our compatibility program. So in future, we can avoid these issues.
https://wpml.org/documentation/theme-compatibility/go-global-program/
With Regards
Bigul
August 18, 2017 at 5:18 pm #1346265
mathieulaflamme
I don't understand because I replied to you in great detail and now I don't see my post anywhere?
August 18, 2017 at 5:25 pm #1346273
Bigul
I have hidden your previous post because you have shared the site credentials in it. It is a public forum so please only share the credentials when the private information option is activated. Because may it will harm your site.
Please grant admin privileges to the user. So I can check your site settings.
With Regards
Bigul
August 18, 2017 at 5:28 pm #1346276
mathieulaflamme
I don't understand, how do I do that? Should I send you an email with the login info? I don't see anywhere private or secure on this page to send you the info. Also, I had the login info on the post you made private, can you see it there? It should work
August 18, 2017 at 5:28 pm #1346277
mathieulaflamme
oh sorry, I got it. I will make you admin in 1 min
August 21, 2017 at 8:26 am #1346991
Bigul
Thank you for the admin privileges. I made a duplicator copy of your live site now. Will debug it locally and get back to you as soon as possible. Please wait.
With Regards
Bigul
August 22, 2017 at 1:49 pm #1348274
Bigul
For your kind updates, few strings were missing for translation in Translation Editor because you have used custom shortcodes(instead of default Visual Composer shortcodes) for an example *split_line_heading*. Therefore the translation configuration is missing for these custom shortcodes in *wpml-config.xml* file.
Please try the following steps after a site backup and let me know your feedback.
1) Visit *plugins/js_composer_salient* folder and open *wpml-config.xml* for edit
2) Scroll down to bottom(to line *206*). Then add the following code before *</shortcodes>* tag
		<shortcode>
                      <tag>split_line_heading</tag>
		</shortcode>
		<shortcode>
                      <tag>nectar_btn</tag>
		      <attributes>
                             <attribute>url</attribute>
                             <attribute>text</attribute>
                      </attributes>
		</shortcode>
		<shortcode>
                      <tag>fancy-ul</tag>
		</shortcode>
3) Save the changes
4) Visit Plugins list, then activate and deactivate WPML plugins
5) Then open the *22 Cavalier Test* page for edit and update the page(just for resaving the page contents)
6) Then open the *22 Cavalier Test* Chinese page for translation in Translation Editor and make sure the missing strings are showing for the translation or not
Please check the following tutorials and attached images for more details.
https://wpml.org/documentation/support/wpml-integration-with-page-builders-that-use-shortcodes/ (Creating a language configuration file for your page builder section)
https://wpml.org/documentation/support/language-configuration-files/#page-builder-content
With Regards
Bigul
August 22, 2017 at 11:08 pm #1348745
mathieulaflamme
I'm not sure where to add the code. There are no line numbers(see screenshot) Also, can you give me advice on how to move forward. The creators of my theme are very slow with technical support. To the point it seems almost unfair. Thank God you have been helping me. I really need this theme to work because graphically it's exactly what I want. Do you see this being a major problem? Is there a way to fix this? I really need to understand what are the implications as I'm about to build a serious website that must work. Any advice would be appreciated.
August 23, 2017 at 4:13 am #1348807
Bigul
Please try with the following *wpml-config.xml* file. You can replace the current *wpml-config.xml* file with this one after a site backup.
Then try the following steps and let me know your feedback.
1) Visit Plugins list, then activate and deactivate WPML plugins
2) Then open the *22 Cavalier Test* page for edit and update the page(just for resaving the page contents)
3) Then open the *22 Cavalier Test* Chinese page for translation in Translation Editor and make sure the missing strings are showing for the translation or not
Please check the following tutorials if you are facing any issue with custom shortcodes or Visual composer and you are always welcome to open new tickets whenever you stuck with WPML.
With Regards
Bigul
The topic ‘[Closed] When I go to translate a page I’ve created using using Salient Visual Composer,’ is closed to new replies.
