Problem:when I switch from english to hebrewand other way around it doesn't work
Solution:within the database table wp_options your 'home' field had the URL added with 2 extra spaces thus the %20 in the URL
Relevant Documentation:
Last updated by reutS 1 year, 1 month ago.
Assigned support staff: Bobby.
April 5, 2019 at 4:07 pm #3545651
reutS
I am trying to:
switch from hebrew to english and the other way around
I expected to see:
or
Instead, I got:
hidden link .
. hidden link
April 5, 2019 at 9:08 pm #3547055
Bobby
this is most likely happening due to the %20 within your URL (this stands there usually for an empty space)
if you paste both urls in your browser and replace the %20 they will work as expected
example:
hidden link .
. hidden link
change them to
hidden link .
. hidden link
If possible please go to WP->Settings->General and share with me a screenshot of your
WordPress Address (URL) and Site Address (URL) , also make sure that there is no added space within the URL name.
additionally if you have access within your database verify the same within wp_options table, these are the first 2 entries usually in wp_options.
April 6, 2019 at 4:26 pm #3549593
reutS
I can't change the url since they appear in the correct form (they are permalinks so I can't change them) I attached a screenshot now of the home page in my WordPress and what you asked for. Thanks.
April 8, 2019 at 5:04 pm #3560317
Bobby
This could be happening due to a 3rd party plugin adding this space into your URL structure.
If possible i would like to take a closer look
**Before we proceed I recommend to please take FULL BACKUP of your database and your website.**
I often use the Duplicator plugin for this purpose See: http://wordpress.org/plugins/duplicator/
I would like to request temporary access (wp-admin and FTP) to your site to fix the issue.
Thank you,
Bobby
April 10, 2019 at 8:42 pm #3581307
Bobby
The issue should be resolve now
April 14, 2019 at 8:44 am #3607249
reutS
