Last updated by frankK-24 9 months, 1 week ago.
Assisted by: Bruno Kos.
November 5, 2024 at 9:36 am #16365008 | |
frankK-24 |
November 5, 2024 at 1:59 pm #16367069 | |
Bruno Kos WPML Supporter since 12/2018
Languages: English (English ) German (Deutsch ) French (Français ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, To better understand what goes on in here, could you provide: 1. A short video showing the steps you’re taking in Bulk Sheet Editor when adding categories. You can use tool such as hidden link Regards, |
November 5, 2024 at 3:43 pm #16367944 | |
frankK-24 |
Hi Bruno, just checking, but is it possible to have a really short video call? I tried to capture it in a video, but it takes over 10 mins and really doesn't make it easier to understand... 🙂 |
November 6, 2024 at 7:11 am #16369858 | |
We don’t offer support via video calls, but even if we did, we would need clear steps to reproduce the issue. Additionally, it may not be easier to identify the problem through a call, as there’s a chance we might miss something important. Are there clear steps to reproduce the issue? If so, you could pause the video during data processing, allowing us to focus on the end result. Would that work for you? |
November 6, 2024 at 8:43 am #16370167 | |
frankK-24 |
Here is the video: hidden link |
November 6, 2024 at 12:32 pm #16371621 | |
Thank you for sharing the detailed video. I’ve reviewed it but I didn’t notice anything obvious that might be causing the issue. Since the problem seems to occur randomly, it’s possible that the underlying cause is tied to a specific set of conditions that aren't immediately visible. While it might seem random, there could still be hidden patterns. For example: Furthermore, testing in a sandbox environment with a smaller set of products and categories (e.g., 10-20) might help us replicate the issue under controlled conditions. Could you check the translation states of the affected products and categories? Are these categories or products consistently untranslated, partially translated, or using fallback translations when the issue occurs? If you’re open to it, we could proceed with some sandbox testing. This will help us dig deeper and potentially identify the trigger for this behavior. |
November 6, 2024 at 3:32 pm #16373459 | |
frankK-24 |
Thanks for your reply. We've done a lot of testing the past 4 weeks to find any patterns. I'm sure there is one, but haven't found it yet. Happens on all categories, all products, etc. All sneakers are English only and use the fallback option. We've created 50 dummy products to test and it's the same on these. All sneaker products are English and don't have a translation status. We don't have a staging area at this moment. Are you able to check our regular back-end? |
November 7, 2024 at 6:35 am #16375278 | |
I’ve marked your next reply as private so you can securely share any necessary credentials. However, I’m not entirely sure what steps I need to take or which products require updating to reproduce the error. I’m also hesitant to make any changes myself, as it could disrupt the product catalog. Could you please provide clear guidance on what actions I should attempt? Additionally, if the issue does occur, where should I look to identify what went wrong? |
November 7, 2024 at 10:43 am #16376411 | |
frankK-24 |
Thank you for getting back to me. I’ve put a lot of hours yesterday to make sure all products are finally attached to the products. Now it looks fine. I have no idea what happens next time when we make adjustments, but honestly I’m a bit tired of this issue, haha! It’s too time consuming. For now I’m going to put this issue on hold. If it happens again, I’ll get back to it. |
